      08-25-2010, 10:30 PM   #1
foxx
Drives: '09 X5 4.8 -'01 330i - '86 911
SPORT MODE
What does really the Sport Button do? When I push it I can feel the car shake a fraction of a sec, but what exactly happens? I imagine the suspension becomes stiffer, gas pedal response might be better, although I don't see why it wouldn't be fast even with normal mode on. But what else?
I know this could be a really stupid question, but as a 10 day new owner of 4.8 xDrive with all possible packages, I'm curious to know what to expect and do I really have.
Thanks all!
      08-26-2010, 07:26 AM   #2
LEDZEP
LEDZEP's Avatar
417
Drives: 2009 E70 & 2011 F25
A 4.8 will all possible packages? Can I be in your Will?
Basically, it just stiffens the suspension - that's all. If you want acceleration and shifting to be more responsive also, pull the transmission selector toward you into "sport mode". You'll notice the difference.
I think it is bad luck to be superstitious
      08-29-2010, 01:06 PM   #3
thlax
Drives: 4.8 X5
Thanks all!
Im pretty sure sport button increases your accelerator pedal sensitivity too. I have a very similar car too. Love it.
Current:
2007 X5 4.8 Black Saphire, Black leather, Sport, Premium, Tech, Cold, 20".
Past:
2010 335xi M Sport
2003.5 e46 M3
      08-29-2010, 01:11 PM   #4
foxx
Well I know when u change the gear shift to DS there's a huge difference in throttle/rpm response, but the SPORT button doesn't seem to make a big difference.
      08-30-2010, 04:24 AM   #5
ronald_adi
ronald_adi's Avatar
Netherlands
39
Drives: X6 40d
The SPORT button is only for the suspension if you have adaptive drive. (and you only have the SPORT button when u have the adaptive drive option). It does nothing to the engine or gearbox.
Pushing the gear lever to the LEFT puts it in sports mode - and THIS is for the gearbox - drops the gear 1 or 2 down, and keeps it at the best possible gear.
It may also sharpen throttle response and sharper steering (if you have adaptive steering), but i am not sure of this.
ronald
      08-30-2010, 08:02 AM   #6
richard in NC
Drives: 2009 Z4 35i
ronald
I'll have to play some more with my new X5 50i but I think Sport mode on the gear shift only changes the transmission settings.
I wonder if Dinan or other upgrades can add more adjustments to the sport mode?
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims
Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i
      08-30-2010, 08:13 AM   #7
ronald_adi
ronald_adi's Avatar
Netherlands
39
Drives: X6 40d
http://www.bmw.com/com/en/insights/t...port_mode.html
      08-30-2010, 08:52 AM   #8
richard in NC
Drives: 2009 Z4 35i
Yes but that doesn't get into the specifics of each model, or each option within the models. I've had many BMWs with a sport button, they all have had varying effects. I think the X5's is only for the adaptive suspension.
      08-31-2010, 09:04 PM   #9
thlax
Drives: 4.8 X5
In my old m3 sport changed accl response.
Well I just hopped in my car and did a lap up and down the driveway w/ and w/o.....now I'm not sure if it changes anything In throttle response. But I always keep it on
Current:
Past:
2010 335xi M Sport
2003.5 e46 M3
      08-31-2010, 10:47 PM   #10
richard in NC
Drives: 2009 Z4 35i
I played around some today. I felt no change in throttle response, but I did feel a slightly tighter steering. That could be from the firmed up suspension but there was a slight difference.
      11-19-2012, 01:50 PM   #11
skunkd
skunkd's Avatar
18
Drives: 2004 STI 2008 BMW M5 2004 530i
From what I notice it's the suspension and steering becomes stiffer and more precise, when the sport button is pressed.
      11-19-2012, 03:59 PM   #12
Jacky
Drives: 2011 X5M
I have the same question for the x5m as well. I noticed the gear difference and performance difference when the car is put into s mode. However M mode, i dont really feel much difference...
      11-19-2012, 06:24 PM   #13
jeremym
Drives: F80
When moving the shifter to the left, that is what changes transmission shift points and throttle response.
The "Sport" button right near the shift lever is what firms up the suspension.
      11-22-2012, 06:55 AM   #14
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
It only firms up the suspension on the non M X5/X6. Even then it is "barely" noticeable. No change in steering or throttle or shifts.
Other BMW models do various things , but not this one. (And I'm not sure about the X5M/X6M)
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      11-26-2012, 06:17 PM   #15
3Bims
Drives: XXX
"Jacky I have the same question for the x5m as well. I noticed the gear difference and performance difference when the car is put into s mode. However M mode, i dont really feel much difference..."
Are you sure that you programmed your M button?
      11-26-2012, 08:09 PM   #16
wsybert
wsybert's Avatar
Drives: 2009 BMW M3 Vert
Correct. It increases the damping stiffness and increases the swaybar resistance. I think it's very noticeable on mine.
2019 Ram 1500. (Toy hauler)
2009 M3 Vert (Fun in the sun)
2006 330i 6sp manual. (Commuter)
1999 528iT 5sp manual (new addition)
