      11-10-2009, 02:41 AM   #1
watoowatoo
Drives: 09 35i X6
Unhappy Brake pads short life!!!
I only have 20000km on the X6 and iDrive tells me that I have to change brake pads in 5000km/~3000miles.
Is this normal at all?
Sometimes I hear a noise from brakes too and this is different from squeaking noise that I used to have last winter. Brake material does not seem to be up to bmw quality comparing with my older 5 series. Please let me know what is your experience.
      11-10-2009, 07:39 AM   #2
Hamed
Hamed's Avatar
Bahrain
Drives: X6
no idea !...better to get it checked soon...dont continue driving it...you will end up spoiling the drums..which will cost you hell of money compared to just the pads..
      11-10-2009, 07:55 AM   #3
NYCGarbagePrince
Drives: X6 50i
1) Modern cars don't use drum braking systems anymore. They use rotors. Still used on heavy trucks though.
2) Your car weighs 2 1/2 tons. There is no compound in the world that will last long enough to stop something that heavy on a consistant basis and last as long as your brake pads on the 5 series.
      11-10-2009, 08:50 AM   #4
vchris
Greece
Drives: Bmw 220i Sport
Wtf!!! I have done 30200km in a year and IDrive tells me to change front brake pads in 26000 and the rear in 34000!!! So this is a bit awkward, i think they warn out very quickly!! Have it checked m8!!
      11-10-2009, 12:38 PM   #5
dmlgc
dmlgc's Avatar
Drives: X6M / 335D
Mine had to be changed at 20K but I drive spirited. The noise you hear could be the sensors, they make a squealing kind of sound. Whenever you hear a noise take it your dealer and have them check it that's why you have warranty. I had break noise at 10k that turned out to be sensors.
      11-10-2009, 02:40 PM   #6
Rac10000
Drives: 981 Cayman S
I'm not surprised that they wear out so quickly when stopping such a heavy vehicle that people undoubtedly drive enthusiastically.
But brakes are covered under BMW maintenance, so wear them out as many times as you want to in 4 year / 50K miles.
      11-10-2009, 03:38 PM   #7
watoowatoo
Drives: 09 35i X6
Sounds similar to my case. I drive spiritedly too.
I don't know if it has anything to do with BMW brake recall, because I noticed part numbers for X6 brake pads have changed after /08.
I will have it checked in two days. I hope it is just broken sensors. Will post back after the check.
By the way I still have to pay for brake parts like pads even under warranty!
      11-10-2009, 06:47 PM   #8
Skywagon
Skywagon's Avatar
12
Drives: X6 3.5
For what it's worth, replaced my wife's brake pads on her Cayenne twice in 37,000 miles. Suspect mostly due to almost all city driving. Also, they are allegedly "high performance" pads, not quite sure what that means, the fronts throw a lot of dust.
      11-10-2009, 07:24 PM   #9
chuck92103
chuck92103's Avatar
44
Drives: 2011 535i
It comes down to how you drive. All highway and the pads will last 50k miles or more.
I suspect you are doing a lot of stop and go or breaking excessively hard.
No worries though. That is what free maintenance is for.
2011 535i
2008 VW GTI
      11-11-2009, 12:23 AM   #10
dmlgc
dmlgc's Avatar
Drives: X6M / 335D
why ? mine were cover under warranty.
      11-11-2009, 12:26 AM   #11
motex
2016 X5 30d
motex's Avatar
Costa Rica
218
Drives: 2016 MW/F15 30d
The reason for the part number change is because they changed the brake pads supplier so they use a new part #
      11-11-2009, 12:31 AM   #12
motex
2016 X5 30d
motex's Avatar
Costa Rica
218
There is a "golden rule" when you drive fast or spirited, the best way to conserve your brakes in terms of duration and less heat is to brake hard and short, that way you will loose a lot of speed in a very short period of time.
If you are used to make long and soft braking periods, there is a lot of friction and heat building into pads and the rotors, so the pads will worn out faster, same for the rotors.
      11-11-2009, 02:44 AM   #13
archwerks
Drives: x6 3.5i VR
Brake Pads Wear
In Canada, warranty does not cover wear & tear items . U have to pay xtra if u want the wear /tear maintenance warranty.
City stop & go driving obviously will wear out ur tires & brake pads / rotors /spark plugs/ motor oil sooner.
U can gear down b 4 u brake to reduce brake wear/heat but transmission maintenance /repair eventually may cost more than brake pads!
Drive spirited on the highways where there's less traffic & so less brake use to scrub ur speed & take it easy in urban driving. Less wear & tear on the suspension & U'll get btr gas mileage too!
Carry the big stick but u don't have to use it.
      11-11-2009, 02:56 AM   #14
dmlgc
dmlgc's Avatar
Drives: X6M / 335D
In US everything except tires are covered. I buy BMW's to drive them and have fun.
      11-11-2009, 06:13 PM   #15
archwerks
Drives: x6 3.5i VR
Speed Judiciously.
Yes. Indeed.
Switch on laser shift rad detector. Check.
Adaptive drive sport setting engaged, check.
Shifter in Sport mode, check
Steering wheel paddles at the ready! check.
Engage the lead foot to the accelerator!
      11-11-2009, 06:40 PM   #16
dmlgc
dmlgc's Avatar
Drives: X6M / 335D
Yes. Indeed.
Works for me !
still looking for a rad detect that I can mount out of view, only seen ones that go behind front grill but heard that they aren't that good. Hum should start a thread on this to get opinions, think I will.
      11-14-2009, 12:28 PM   #17
watoowatoo
Drives: 09 35i X6
great advice from everyone! I took it for service and was told that this is normal for this car depending on the driving style. So I guess I will keep it cool in city traffic.
The new question then would be how much regular kick downs will affect transmission life! (or DOING lunch control- revving a little before releasing brake)
Tags
brake, life, pad
