Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
      04-10-2009, 03:33 AM   #1
Antinontoxic
Antinontoxic's Avatar
Finland
51
The BMW X5 Performance Tri-Turbo Diesel
It has not been yet confirmed with multiple sources, but the rumor mill has it that BMW is developing a tri-turbo diesel engine based on the six-cylinder turbo existing in the BMW line-up. The tri-turbo engine will output 354 horsepower and it will be initially used in a BMW X5 Performance Diesel.
This new engine will carry the EfficientDynamics badge by incorporating technologies like Start-Stop system and Brake Energy Regeneration (KERS). It will be geared towards the European market in need for a top X5 model.
BMW X5 Performance Diesel has less pronounced wheel arches that the ones seen on the new BMW X5 M . The Wheels give the car very sporting and powerful appearance. The aerodynamic performance package follows the design of the X5 M, but the central intake is smaller with the intakes for the brakes less open mouthed and a colored bar across .
Same source, someone close to BMW, speaks of subtle spoilers for air flow at the leading edge of the bumper. The rear of the car features two larger and more exposed performance exhaust pipes which will be incorporated in the upcoming facelift of the X5.
http://www.bmwblog.com/2009/04/10/ru...ne/#more-12123
http://www.germancarzone.com/x5-sav/...ce-diesel.html
      04-27-2009, 02:53 AM   #2
Deda
Deda's Avatar
Croatia
107
Drives: BMW 640xd San Marino blue
nice...more power!
      05-13-2009, 06:10 PM   #3
Artz 330
Drives: Z4M, 335i, 135i
2006 330i  [0.00]
A tri-turbo setup will be used on the next version of the Petrol 3.0L N54B30A. Word on the inside is that this is already being tested.
      05-13-2009, 06:27 PM   #4
chuck92103
chuck92103's Avatar
50
Drives: 2011 535i
As crappy as the Mitzubishi turbos are and the failure rate BMW has encountered they should put 6 turbos in the beast with 3 as hot spares.
A 335's turbos go down more than a hooker on broadway and there is still no permanent fix in site.
2011 535i
2008 VW GTI
