BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > New H&R Anti-rollbars/Sway bars
      04-14-2024, 06:28 AM   #1
jwrag2000
Drives: Bmw 330d e93
Planning to install thicker than stock anti-rollbars as my e93 330d has awful body roll expecially in the rear. My question is do these H&R bars use the stock drop links or is something else required.
In addition to reducing body roll what other impact is likely? Will ride comfort be reduced? Is it true that the less body roll leads to reduced grip at the limit as weight transfer is reduced.
      04-15-2024, 06:20 AM   #2
wrevilo
Drives: 2010 E92 335i N55 6MT
Do you have new or upgraded springs and dampers? I would change those before considering trying to tune suspension with roll bars.
335i54n318.50
      04-15-2024, 08:08 AM   #3
jwrag2000
Just bone standard Bilstein B4s and stock non M sport Sachs springs. Only upgrade is m3 arms where possible front and rear.
My approach is to improve handling without adversely effecting ride, hopefully a stiffer ARB will give this as they don't do anthing unless in a corner?
      04-15-2024, 02:11 PM   #4
335i54n
Drives: e90 335i, e39 m5
tires and rims size? imo wider, better (michelins) and low profile setup not only upgrades looks but also driving dynamics. yeah i would do b8 and springs (oe msport) and front bar (1st/only)
whyzee1251704.00
Tags
anti rollbar, body roll handling., sway bar
