BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Help with alignment issue
      04-10-2024, 09:40 PM   #1
Nick54
Drives: 2010 e92 335i xdrive manual
I installed the M3 rear arms on my 335xi and now the alignment shop says they can’t get it aligned. he said the toe arm is too short (too much toe out). I didn’t replace the toe arms in the rear, just the upper and forward arms as seen in the picture. did i do something wrong?
I bought dinan arms and the arms are installed as follows
left forward AK36F
Left upper AK03G
right forward AK11G
right upper AK23F
Any help would be super appreciated
      04-10-2024, 10:22 PM   #2
335i54n
Drives: e90 335i, e39 m5
so much rust, you probably have issues with both toe and camber eccentrics. if u did just the arms it shouldnt be too much out of adjustment but imo looking at the rear i wouldnt have even put those in.
      04-11-2024, 06:17 AM   #3
Nick54
All bolts move freely. do you think simply having msport springs is throwing everything off?
      04-11-2024, 01:03 PM   #4
335i54n
no, msport height or even little lower will still have enough adjustment to get in spec
      04-14-2024, 02:12 PM   #5
Nick54
so basically change alignment shop?
      04-15-2024, 02:14 PM   #6
335i54n
with what u stated, yeah second opinion with explanation and data (printout)
Nick5410.00
