01-02-2020, 05:58 PM | #1 |
Rep 364
Bootmod3 N55-EWG Version 7.0 is up !
Spent some time with an 435i on our dynojet to squeeze out some more power and torque. Baseline was low on this particular car but increase in percentage was 🔥 Mods are Wagner intercooler and downpipe Stage 2 93 octane V6.4: 26% HP / 38% TQ Stage 2 93 octane V7.0: 29% HP / 48% TQ Stage 2 E30 octane V6.4: 29% HP / 44% TQ Stage 2 E30 octane V7.0: 33% HP / 56% TQ Graphs attached are in HP/LBFT and PS/NM - all measurements are done at the wheels! Version 7.0, January 03, 2020: - Boost target changes - Boost and load control - Power increase Last edited by Halim@HCP; 01-02-2020 at 06:01 PM.. Reason: Title was wrong |
10
ronanz1822.50 Yungsta126.50 wjjkoevoets1165.00 G80S58135.00 ctt30047.00 ali820273.50 jmack550.00 Jake From State Farm54.00 Infamous039147.50 1bad14-F3030.50 |
01-02-2020, 06:13 PM | #2 | |
Rep 192
01-02-2020, 06:17 PM | #3 |
Rep 364
BostonM235xi130.00 1bad14-F3030.50 |
01-02-2020, 06:36 PM | #4 |
Rep 192
01-03-2020, 08:12 AM | #5 |
Rep 364
1bad14-F3030.50 |
01-03-2020, 01:21 PM | #8 |
Rep 1,499
This is pretty nuts. Based on my baseline dyno from December 2017 (can't remember which OTS map version) of 311whp/320wtq (on Stage 2 91ocatane with shitty CA gas) I should be at 401whp/474wtq on Stage 2 93octane and 414whp/500wtq....SAY WHAT 500 WHEEL TORQUE!! Not to mention I'm now in a 93 octane state and running WMI. Time to get on the dyno!!
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
Jake From State Farm54.00 |
01-03-2020, 01:39 PM | #9 | |
Rep 643
01-03-2020, 04:04 PM | #10 |
Rep 1,499
I'm about to right now. I just switched to my winter tire setup which are some el cheapo all-seasons which don't hook nearly as well as my Continental Extreme Contact Sports, which are also much wider so I do have boost be gear reduction in place, 20% for 1st and 10% for the second. 3rd - 6th has full boost. I'll provide a review tomorrow morning.
01-03-2020, 11:03 PM | #11 |
Rep 289
Just tried the e30 V7.0 map. Getting flat spot at 28-2900rpm or so and would kick right back in.
I'll probably log soon but I want to try the same test drive on the e30 V6.7 first and see if it's does the same thing. New map does have gains you can feel right away. Definitely an upgrade just need to work the smoothness abit, ill test the V6.7 first before I get a log and send to support. |
01-03-2020, 11:50 PM | #12 |
Rep 289
Update2:
The V6.4 is smoother for me . Did the same testdrive and flat spot at 28-2900 is not there. I'm still new to BM3 I'm a cobb accessport world datalog kind of guy. I sent a request claim on the website asking if there are parameters they want me to log. I know it's OTS and won't be perfect but the flat spot in V7 is there around 28-2900 and will be a jolt of kick right after. On the V6.4 the flat spot is not there at 28-2900 but maybe a minimal one around 33-3400 ( again it's an OTS so I'm not looking for perfection). Plugs are new probably less than 500 miles OEM. EDIT: https://f30.bimmerpost.com/forums/sh....php?t=1374308 Found the above thread via Google University and somewhat intrigued by the manual transmission claims since sounds like the problem I posted on V7 is spot on. Anybody else had same issues on the new update ? Update 3: I drove the v6.4 e30 map this morning. 100% throttle input no break up in 3rd or 4th. |
01-04-2020, 09:01 AM | #13 |
Rep 4,210
The E30 map just doesn’t seem like a good trade off for worse fuel economy. I think it’s best used for a track day to keep the engine power more consistent and cooler.
01-04-2020, 11:02 AM | #14 |
Check out my Youtube @n55david!
1305
Rep 3,554
Drives: 2017 m240i, 2015 X3 x35i
I noticed almost no difference tbh, but i drive it easy when im not messing around with another car.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
01-04-2020, 12:16 PM | #15 |
Respect My Authoritah
368
Rep 873
I flashed mine with boost reduction in gears 1,5, and 6. I was running 80% in both 1 and 6 and after flashing, there was no power to those three gears. It seems that this update broke that function. Now it's like that slider controls throttle, not boost.
I removed the boost reductions and it fixed the issue. I now see that boost initially spikes to over 20psi and then settles back to 17psi for Stage 2 91 Octane. Is this a problem? The tune does seems smoother and more powerful.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
01-04-2020, 12:47 PM | #16 |
Rep 142
Flashed Stage 2H E30 7.0 and looks very nice and feels even better! Here’s a 4th and 5th gear log. Max target boost increased to 17.9 PSI from 17.2 and I presume load has been upped over V6.4. Great job Halim and PTF team! Thanks for all of your hard work.
http://www.bootmod3.net/log?id=5e10cbb0c090c64cbd8430d6 |
01-04-2020, 12:50 PM | #17 |
Rep 142
I've been running E30 maps for 2 years and recently went to the stage 2H E30 maps and always average 18.6 to 19 mpg 40/60% highway/city driving. I hand calculate mileage from miles driven per filled gallons.
Last edited by ctt300; 01-04-2020 at 12:52 PM.. Reason: Added detail for mpg calc method. |
01-04-2020, 01:51 PM | #18 |
Rep 289
Update 4:
I went ahead and removed my sparkplugs (500ish miles new) OEM Bosch and regapped them down to .022. I'll reflash the e30 V7 in a bit and try to see if it'll break up in the 28-2900rpm spot like last night. EDIT: Gilberto Diaz Drove a lot better but still a little kink in the Armour mid range around 32-3300 on V7. I did about 5 pulls like last night and the "flat fall of its face 28-2900" is gone. It drives a lot smoother than yesterday. I didn't log , gonna need to do it tonight too many cars to do a legit real log. I live in the heart of the Bay Area California lol. Freeway is packed. I am still waiting on PTF for there requirements parameters for datalogging. I'm confident enough to run this map as is for the weekend and see how it fairs out. |
01-04-2020, 01:55 PM | #19 | |
Rep 7,629
And who cares about fuel economy anyways? Its about smiles per gallon. |
01-04-2020, 10:57 PM | #20 |
Rep 6
Hey PTF, does cat heating off have any detrimental effects on a high flow cat apart from NOX environmental impacts?
My neighbours would certainly prefer that I have it off. I upgraded to 7.0 today and noticed that the default settings (nothing changed in map config) had the cat heating off. I changed it to OEM and reflashed to turn it back on. |
