03-15-2019, 01:27 PM | #1 |
Rep 1,252
What Did You Do To Your E70 Today?
Most forums have this thread, they usually do pretty well and have some interesting stuff. Even small things, pictures, anything!
03-15-2019, 01:29 PM | #2 |
Rep 1,252
I'll start it off...
I installed some heat wrap onto the crossover pipe that likes to crack from all the heat. Maybe it will help, maybe not. Might be worse! But it's supposed to reflect and protect, and I'm a believed with the tape on my intake pipes. They went from not being able to touch them to a cool to the touch feel. I also got rid of the final thin hose clamp on the intake side... I kept ordering the wrong size t-bolt clamp... |
03-15-2019, 01:40 PM | #3 |
Rep 357
Drives: E70 X5M
Today I gave the M a thorough cleaning. Went over some mountain passes for work this week and needless to say it was the dirtiest any car I've ever owned was. Pic shows everything that washed off - the driveway isn't red that's just all the dirt they throw on the roads. Dirt baked onto the exhaust tips as well so polished those up after this pic.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
03-15-2019, 01:52 PM | #5 |
Rep 357
Drives: E70 X5M
Thanks man I'm loving the LED headlights as well! Wonder if the laser headlights will be on the new X5 M when it comes out. Now those are something to drool over!!!
This thread is an awesome idea. I'll eventually start a journal as I install all the mods I have lying around but this is good for the little things we tinker with day in and day out.
9vapors651.50 |
03-15-2019, 03:45 PM | #7 | |
Rep 235
9vapors651.50 |
03-15-2019, 05:17 PM | #8 |
Rep 357
Drives: E70 X5M
Is that a FMIC? Which E70 are you driving?
03-15-2019, 08:27 PM | #9 |
Rep 235
03-16-2019, 06:50 AM | #10 |
Rep 328
How did the install go? There are a couple small modifications that need to be made on the bumper bracket correct? Need to get around to installing mine sometime soon but want to finish the catch can first so I avoid spraying the new clean ic down with oil! |
03-16-2019, 11:49 AM | #11 | |
Rep 235
03-16-2019, 01:20 PM | #12 | |
Rep 235
03-16-2019, 01:48 PM | #13 | |
Rep 328
No kits made for the M57 but will be plumbing in a Provent 200 with a custom PCV plate to run an elbow fitting off of. Here are the parts I have on hand so far: MANN Provent 200 - 3931070550 MANN Provent Check Valve - 2400843621 Moroso Dry Sump/External Oil Pump Fittings - 22622 Fragola Performance Push-Lite Hose Ends - 209016-BL Fragola Performance 16AN bulkhead nut - 492416-BL Patrick Motorsports 24mm-ID Braided hose - 6ft - HAR 930 107 394 5M HPS 32-37mm Stainless Steel T-Bolt Clamps x 4 - SSTC-32-37 Custom milled PCV plate Check out this thread - 35d: adding crankcase breather oil separator Still need to figure out what I'm going to do for the oil return. Wanted to do it in a cleaner way than a brass tee fitting JB welded into the middle of the dip stick line like was done in the thread so haven't ordered those parts yet. Last edited by Deftronix; 03-16-2019 at 02:02 PM.. |
03-16-2019, 02:54 PM | #14 | ||
Rep 235
03-16-2019, 04:51 PM | #15 |
Rep 210
Swapped out the original X5M rear badge for an all black one. The //M was fading, so I thought I'd try a different look.
2013 X5M
2011 X5 35D Sport Package 2002 M3 2019 i3 |
03-16-2019, 05:45 PM | #16 |
Rep 357
Drives: E70 X5M
Looks good man. Going the same route soon.
03-16-2019, 07:51 PM | #17 |
Rep 1,252
Yup nice work, should have come factory that way...
I washed mine! |
Nexo13.00 keith mellon0.00 |
03-17-2019, 12:16 PM | #19 |
Rep 210
Rear brakes on my wife's 35D and admiring the black emblem on the //M... The M3 has been a bit neglected lately, had to buy a battery tender for it yesterday as it was dead. Looking forward to some warmer days get some top down cruises in!
2013 X5M
03-17-2019, 02:26 PM | #21 |
Rep 433
Installing M roof rails on my X5d today. Took 4 hours to remove the headliner and stock roof rails
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
03-17-2019, 02:29 PM | #22 |
Rep 3,040
Drives: 2022 BMW X5
nice going guys, if somebody started this thread 3-4 years ago we would be on part 7 by now
anyway I took my car to town today, had to bring my gf's sun to bus station (college break is over) Boston streets are pretty tiny and half of those streets are brick sidewalks... I'm flying to China in couple of days so I'll probably be MIA for couple of weeks... cheers and Happy St. Patrick's day
spadesnortheast0.00 Chrisnytx33.00 |
