04-11-2018, 07:29 AM | #3 |
Rep 1,720
Judging by the pictures alone, it looks like your rear tires have a taller than "normal" sidewall. In 22", you should be running 30F/25R. What specs did you order your tires in? The tires should have the same diameter left and right, but also run close to factory ratio front to back.
04-11-2018, 03:53 PM | #4 | ||
Rep 16
04-11-2018, 04:25 PM | #5 |
Rep 397
Your tires need to run at the same rolling diameter +/- a 3-4% allowable difference ... anything bigger and you risk causing damage.
I wouldn't drive like this to much |
04-11-2018, 04:27 PM | #6 |
Rep 16
