      01-14-2018, 01:00 PM   #1
Vortechys
Drives: 2011 335d m sport, 2010 X5M
E70 X5M Electric Exhaust Cutouts
Hi All,
I finally finished the installation of my Doug's electric cutouts and they worked out perfectly.
I picked the Doug's Cutouts because they are a guillotine style. This design allows complete closer of the cutout . No exhaust leaks and is self cleaning.
Packaging it in the rear of the car allowed the exhaust to exit to the back and allowed nice packaging as well.
I did not want to modify the dash or interior for an activation switch so I decided to get a Gama Electronics RF12V1PR-ASL remote control system. This wasn't expensive( about 65 bucks) and is made here in the good old USA.
Overall the installation was not too difficult and the results were well worth it.
I didn't want to buy an aftermarket exhaust system . Now I have the best of both worlds.
Quiet stock exhaust when I want
, and wide open exhaust with a push of a button.
      01-14-2018, 05:24 PM   #2
Ryan5034
Drives: 2019 X5 50i
I bet that sounds fun. any videos yet?
      01-14-2018, 06:41 PM   #3
nmgunner
nmgunner's Avatar
41
Drives: 2013 X5M
Originally Posted by Vortechys View Post
Hi All,
That is awesome. Was it DIY or shop? Do you have a parts list and guide to put it together?
      01-14-2018, 08:36 PM   #4
Vortechys
This was a DIY. I've got a lift which helped with laying everything out.
As far as the parts list.
1. 1 pair of Doug's 3" exhaust cutouts
2. 2 Pypes 3" Y pipes (stainless)
3. 1 Gama Electronics RF12V1PR-ASL remote control system
You can buy Doug's cutouts in a kit including the Y pipes but the pipes are not stainless. That is why I used the Pypes .
You have to cut an oval shaped hole in each pipe. I figured out where I wanted them and then marked the exhaust pipes.
I removed the whole exhaust system and welded it off of the car. It's a trial and fit process.
I just used the sections of the Y pipes for the collector flange pipe. Basically cutting that piece off and fitting it to the original exhaust system
Once I had the Y pipe section fitted where I wanted it , I just tacked it in place and then installed it back on the car to make sure clearance's were correct and that they lined up properly.
Be aware the left and right sides are not symmetrical.
Once that was done, I took the exhaust back down, outlined the Y pipe collector piece and then removed the tacks so I could open an oval in the original exhaust.
Everything was mig welded with stainless 308 wire with trimix gas. You can tig weld it if you want beautiful looking welds.
Wiring is straight forward . I used the fuse box in the back for power. I used a fuse tap and took power from the power tail gate. That way, I could open the exhaust before starting the car if I wished.
If you have any other questions , let me know.
      01-14-2018, 08:50 PM   #5
nmgunner
nmgunner's Avatar
41
Drives: 2013 X5M
Thanks vortech!!
I would love to do this. I had the same kind of setup on my z3m Coupe. I could do most of the work back then but now have kids and a biz. Thanks for the guidance. I appreciate it!
      01-14-2018, 08:56 PM   #6
Vortechys
I forgot to say ,that if you just buy a 4' section of 3" stainless exhaust pipe and some stainless flanges you can bypass buying the Pypes Y pipes.
This would be cheaper with just a little more welding.
      01-14-2018, 08:58 PM   #7
nmgunner
nmgunner's Avatar
41
Drives: 2013 X5M
Cool. I have some employees that do welding so I will hit them up. I appreciate the guidance!
      01-14-2018, 08:59 PM   #8
Vortechys
Your welcome
      01-14-2018, 11:17 PM   #9
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
That looks awesome please post a sound clip
      01-15-2018, 08:02 AM   #10
yco
i'm just saying
yco's Avatar
5725
Drives: E71 X6M '10 (sold)
and the sound please.. wondering actually.. and feel any performance difference?
      01-15-2018, 08:39 AM   #11
Vortechys
I'm not sure how to do the sound clip or video and attach it to the post.
If I figure it out , I will post it.
Sound is not bad at all. Not too aggressive , unless you rev it.
I have not had a chance to drive the car , due to all the snow and ice around here.
Thanks guys.
      01-15-2018, 08:41 AM   #12
protecon
*May contain nuts
protecon's Avatar
Australia
193
Drives: 2010 X5M MCB
Probably exactly like cutting off your exhaust.
      01-15-2018, 09:36 AM   #13
boneca
boneca's Avatar
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
awesome project
how much was the project all in? parts (including remote control), labor etc.?
      01-15-2018, 12:28 PM   #14
gixxerboy63
Tanzanite Blue II X5M Pilot
gixxerboy63's Avatar
1034
Drives: M3, M4, X3 M40i, X5M
2017 m4  [0.00]
2010 BMW X5M  [10.00]
I may have to do a version of this for my Akrapovic.... My vacuum flaps still do not work consistantly or on demand with the M button.
I am hopeful that I will be able to resolve this issue through setting in the DME with Autologic... if not, then this may be the only option.
Thanks for posting!
2020 X5M - Tanzanite II
2012 M3 - Alpine White
      01-15-2018, 12:28 PM   #15
Naz24
Naz24's Avatar
Drives: W205 AMG C63 / E70 X5M
This is definitely the first time i've seen that in an X5M, seems to be big with the chevy etc crowd.
Really cool system, glad the exhaust worked out for you.
PS, Bravo on keeping your tips that clean!
2017 C63
2012 X5M
SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i
      01-15-2018, 12:29 PM   #16
Naz24
Naz24's Avatar
Thanks for posting!
I had the same problem until i lubed the flaps up. Make sure from the outside that the spring is working and the connections are properly lubed. Works perfectly now
2017 C63
2012 X5M
      01-15-2018, 12:49 PM   #17
Vortechys
Thanks everyone.
I would say I have about $450 in the parts alone.
The labor was mine and a friend...free
boneca1999.50
Naz241627.50
      01-15-2018, 09:21 PM   #18
Amstaff
Drives: 15 escalade
Looks good!
      01-16-2018, 07:26 PM   #19
Vortechys
Here are some additional pictures to give you some idea of where to cut out / place the pipes.
I hope this helps some of you wanting to do this to your X5M
      01-17-2018, 12:14 PM   #20
yco
i'm just saying
yco's Avatar
5725
only problem with this when you get closer to car its obvious that noise is coming under the car.. used for a while in my Leon Cupra 8-9 years ago..
