BMW 3-Series (E90 E92) Forum
Bent h&r swaybar
04-26-2008, 07:57 AM | #1 |
Rep 370
Bent h&r swaybar
Can someone confirm for me that the sway bar is bent and no good?
I have a gap on one side and none on the other. Are they made this way? |
04-26-2008, 10:34 AM | #2 |
Rep 1,764
04-26-2008, 08:06 PM | #5 |
Rep 946
I can't believe that swaybar can be bent so easily especially on a short section like that. You would think it would crack first. I would def. call the manufacturer or try and find another one to compare. GL
04-26-2008, 09:58 PM | #6 |
Rep 370
It is a used bar. The only thing I can guess, Is a large pothole on a lowered car. I dont know if lowering the car puts more weight on the bar making it more susceptible to damage. I wish a sponsor would take the time to compare the bar . I will buy a new one and post pics in a few days.
04-27-2008, 08:37 PM | #7 | |
Rep 1,764
Orb |
04-27-2008, 09:05 PM | #8 |
Rep 370
04-27-2008, 11:47 PM | #9 |
Rep 1,764
04-28-2008, 02:51 AM | #10 |
Rep 3,432
05-15-2008, 01:15 PM | #11 |
Rep 370
As it turns out the bar is normal. I ordered another one to compare and they are exactly the same. Thanks for everyone's help. I had it installed and wow, what a difference. This is the way the car should handle from factory.
05-15-2008, 01:28 PM | #12 |
Rep 2,225
Thanks for posting your outcome. I have H & R's on order, which I hope to have within a few weeks. I would have had the same questions about the "bend" that you did. good luck with the new set up!
07 335i sedan | Steptronic | Black saphire | Terra | ZPP | ZSP | Cold Weather | CA | PDC | Nav | OEM Alarm
05-15-2008, 01:38 PM | #13 |
Rep 6,750
Glad to hear. It's hard to imagine a pothole or poor installation being capable of bending a bar like that. The bar is not aluminum, and it's designed for rigidity, so bending would not be easy unless it were heated to soften the metal or involved in a major accident.
05-15-2008, 09:20 PM | #15 | |
Rep 2,225
I appreciate you confirming what the op has found out as well!
06-19-2008, 04:08 AM | #17 |
Rep 1,053
i was gonna say, aren't sway bars hard to bend? they're really really thick. if they're bent, i think you can see the paint crack too or some stress marks on it.
2008 335i coupe Atlantic Blue with Black Leather Steptronic ZSP ZPP NAV PDC COMFORT ACCESS REAR SUNSHADE HEATED SEATS HD RADIO SIRIUS USB/IPOD 20" Klassen K5.1 3-piece wheels w/Toyo Tires Job Design Body Kit M3 Trunk Spoiler Eisenmann Exhaust Eibach Pro-Kit Springs
06-19-2008, 03:47 PM | #18 |
G.O.A.T.!
1002
Rep 74,998
It's always in your best interest to contact the manufacturer directly with pics or issue's that arise. I know first instinct is to ask here and hope for the right answer but while guys are trying be helpful sometimes you just get tons of misinformation!!
11-01-2015, 10:00 PM | #20 |
Rep 741
Drives: E87 130i
Rather than start a new thread, I figured I'd dig this up as it appears to be the a similar issue.
Photos of a brand new bar can be found attached- appears bent. Thoughts? |
11-01-2015, 10:04 PM | #21 |
Rep 741
Drives: E87 130i
