09-06-2015, 12:03 AM | #1 |
Rep 460
Front Driveshaft Broken
Hi everyone! Unfortunate news on my 2012 X5 50i M sport. First it was vandalized with paint stripper (re-painted and looks gorgeous) and now my wife was driving in the highway and the front driveshaft broke. She pulled over and had the X5 towed. Was towed with rear wheels on ground off the highway and then on a flat bed truck to the BMW dealer.
Here's what the BMW dealer found and fixed: Front driveshaft came apart and damaged transmission sump and heat shield. Replaced front driveshaft and bolts, transmission sump and transmission underbody shield. Added 1 quart of transmission fluid. Part number of driveshaft is 26-20-8-605-866 drive shaft A 2 Service advisor said the driveshaft part is an updated part that fixed the problem. Funny thing is that I asked them to check the driveshaft just a few months ago as a precaution because I knew this was happening to others. I have two questions for the forum: 1. Should I be worried about any other transmission damage? Will problems come up in the future? Should I replace all the transmission oil? Car rides fine now. 2. Should I be concerned about the rear driveshaft? Should I have them replace it with an updated part? Thanks!
2008 E90 335i: JB4 G5 ISO | BMS Pump Gas Backend Flash | ER Charge Pipe | n54Tuning DPs | ETS FMIC
09-06-2015, 07:15 AM | #2 |
Rep 1,544
Drives: '22 Tesla MY + '23 Tesla MY
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
09-06-2015, 08:31 PM | #4 | |
Rep 460
I thought RWD BMW also had to be towed on a flat bed?
09-07-2015, 07:24 AM | #5 |
Rep 293
Same thing happen to mine... Except they replaced my complete transmission, front driveshaft and transfer case. Over 16K in damage all warranted.
I'd like to think in your case they replaced all necessary. You should be okay. |
09-07-2015, 08:07 PM | #8 | |
Rep 600
Although mine is a MY2012 and it has the doomed drive shaft ... See also - http://www.xbimmers.com/forums/showthread.php?t=995198
PAX5
BMWCCA 20645 Last edited by PAX5; 09-08-2015 at 09:34 AM.. |
09-07-2015, 11:27 PM | #9 |
Rep 460
Mine is 2012 X5 50i M sport.
09-07-2015, 11:30 PM | #10 |
Rep 460
did they say how they diagnosed to know the transmission and transfer case had to be replaced?
09-08-2015, 09:31 AM | #12 |
Rep 600
No warning signs ... depending on speed, can be catastrophic failure. BMW Aug 2015 letter is to only offer extended warranty.
Find out if you have the doomed part number and stand your ground on having it replaced BEFORE it fails! |
09-08-2015, 11:48 AM | #13 |
Rep 11,891
Thanks. The PN you posted is the replacement # or the doomed number?
09-08-2015, 12:16 PM | #14 |
Rep 2,083
So,
Is this a recall or no? I don't have any noise or vibration but I will like to check if I need it or no before it fails at high speed.
09-09-2015, 01:18 PM | #17 |
Rep 128
easier said than done. The dealer won't replace it under warranty if it's not broken, even if it's destined to break some day. Unless you are already out of warranty and/or feel like dropping a few grand out of pocket, it's probably best to just wait.
09-09-2015, 04:15 PM | #18 | |
Rep 600
To get a diagnosis like that may in part depend on your relationship with the dealer.
PAX5
BMWCCA 20645 |
09-12-2015, 12:10 AM | #19 |
Rep 460
09-12-2015, 07:45 AM | #20 |
Rep 4
Broken Driveshaft
Took delivery of a 2012 X5 and 24 hours later the front driveshaft came apart wasting the transmission, transfer case and twisted the skid plate like it was make from a soda can. Dealer said they have never had this happen before. That may be correct for that dealer but sounds like a design flaw. Some $19k in repairs later I am enjoying the car and have some comfort in knowing I have 2 years of warranty on the replaced parts.
09-12-2015, 08:39 AM | #21 |
Rep 828
Warranty does not apply here. It is a TSB.
