PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
TE37 SL question
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
07-13-2015, 06:55 PM | #1 |
new mods coming soon
10
Rep 114
TE37 SL question
trying to obtain this look will this offset achieve it: 19x9.5 / 5x114.3 / +22 front and 19x10.5 / 5x114.3 / +22 rear
also, what tire size would I need thanks |
07-14-2015, 03:41 AM | #3 |
Where'd my VTEC go?
481
Rep 6,067
BMW bolt pattern is 5x120 not 5x114.3
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
07-14-2015, 12:54 PM | #5 |
Rep 2,823
Not going to happen with adapters. Those specs are aggressive and will get even more aggressive with adapters. Those should be re-drilled/insereted to 5x120, so the offset stays the same.
If you want to fit them you will need negative camber to front and rear. Fender roll to max at rear and some shaving to that bumper/fender bracket. Since you have lci the et22 is quite aggressive at rear. Since you have xdrive basically only tyre sizes that work for you is 225/35/19 and 255/30/19. Also this kinda setup needs coils and i recommend getting something with stiffer spring rates and FK bumpstops would be good idea. Here is E90 Lci with those wheel specs. Rear tyre is narrower but you can't use that combo. http://www.e90post.com/forums/showthread.php?t=543546
07-15-2015, 02:10 AM | #7 | |
Where'd my VTEC go?
481
Rep 6,067
