06-22-2015, 08:24 PM | #1 |
Rep 266
X5 35d Dyno results
Went to a dyno day on Saturday at FSR.
4th gear runs Put down 229.85 hp @ 3461 RPM (73 MPH) 392.31 ft lbs @ 1901 RPM (39 MPH) Was 94F so I got some heat soak on the second run, let it cool off and ran the last pass. The Tq readings are from calculations based on the HP rating and corrected speed. we weren't able to get the optical pickup set up and we didnt know what wire to tap for RPM to get the TQ reading. Plug this info into several calculators and you get the same numbers the dyno would give. 4th gear ratio 1.14 axle ratio 3.64 tire height 28.6 corrected speed ~ 3% @ 70mph due to BMW making the speedo run fast. Last edited by temporaptor; 06-22-2015 at 08:33 PM.. |
06-26-2015, 12:43 PM | #3 |
Rep 11,891
those are pretty good numbers!
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
06-27-2015, 06:15 PM | #4 |
Rep 241
Pretty close to the baseline numbers on my 335d. I think I was at 237hp (different dyno and/or different weather conditions). I did a second run with a JBD piggyback and made an additional 55 rwhp
