      01-17-2015, 10:45 PM   #1
WallyM5
WallyM5's Avatar
42
Drives: X5M, R63 AMG, F-450
X5M Spark Plug DIY
The moment all of you have been waiting for, a spark plug DIY:
Well maybe it was just me that wanted one, I search high and low and could not find anything, so I made one.
First off this is a simple job and doesn't really require any special skill. At first glance it looks complicated because of space but once you move a couple of things it's was a piece of cake. Compared to changing spark plugs on a S85 this was too easy.
Only one key item that you must have before starting this project is a Beru 14 Bi-Hex Spark Plug Socket, part #0890 000 004. http://www.beruparts.com/product.sc?productId=12 Standard spark plugs sockets will not work.
Tools:
10mm socket
6mm socket or nut driver
some 3/8 extensions
torque wrench: torque plugs to 23nm or 17ft lbs
1. Remove upper cover from the intake.
2. Use 6mm nut driver and loosen both intake ducts so that you can remove the air intake filters.
3. Lift up and remove the intake filter housing.
4. Lift up and remove engine cover.
5. Driver's side: use 10mm socket and remove one bolt holding the black bulb over the spark plugs
6. Fold that black bulb thing back to expose the coil packs and spark plugs.
7. Remove coil pack by lifting the the locking tab to release the wire connection, then using the coil pack locking tab pull it striat out with a little force to remove it. You may need to twist it the coil pack back and forth first to make it easier to pull it out.
8. Remove plug, install new plug, torque to 23nm.
9. Push coil pack back one and connect wire back.
10. Once that side is done re-install black bulb and make sure all the wires in that area are secured back in their clips.
Passenger side:
1. Remove the coolant reservoir tank, by removing two bolts with the 10mm socket.
2. Fold it forward by the light housing to get it out of the way.
3. Remove the black bulb on this side as well and move it out of the way.
4. Remove coil pack
5. Remove plug, install new plug, torque to 23nm.
6. Re-Install coil pack and wire connection
7. Re-install black bulb back to it's area and secure wires.
8. Re-install coolant reservoir
Finish up by putting the cover back on, and reconnecting the intake housing.
Sorry about the pictures for some reason some were turned, maybe one of the moderators can fix this for me.
"An on ramp is a terrible thing to waste"
EuroCharged Tune--QTP 3" Cutouts--V1 Hardwire--K&N Carbon Delete
OEM Muffler Mod--(Best Mod Ever) 15mm Front Spacer--20MM Rear Spacer
      01-18-2015, 11:16 AM   #2
theonesupreme
theonesupreme's Avatar
11
Drives: X5M
Good Post
X5///M WHITE, VELOS STAGE 2, AKRAPOVIC DOWNPIPE + FULL EXHAUST, KW V3 , VORSTEINER FRONT LIP + REAR DIFFUSER.......ETC
      01-18-2015, 01:58 PM   #3
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Great write up, thanks!!!!
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      02-01-2015, 08:53 PM   #4
novablackm3
Drives: Performante, G05 M50i, RR SVR
how many miles did you change yours at ?
Huracán Performante 18- Novitec Springs | RR SVR 19 | G05 X5 M50i | E70 11 X5M retired |
Jerez Black E92 10 m3 RE SSK | AFE Filter | Fabspeed XFC / Xpipe | AA ECU 1.5v | BMW PSW | Envy Charger | Megan Exhaust
      02-03-2015, 09:39 AM   #5
WallyM5
WallyM5's Avatar
42
93,000, But they were also changed at 30 & 60
      06-13-2015, 05:54 PM   #6
j1275
Drives: 2012 X5m
Hi,
I apologize for the necro post, but can you tell me what the gap size is for the plugs on a stock vehicle?
I understand that they may come pre-gapped since they are BMW OEM plugs, but I want to check anyways to make sure they are all within spec before I swap out the old plugs.
Appreciate you taking the time to do a write up, nicely done!
      06-13-2015, 11:45 PM   #7
TROYJEUP
Drives: All of them
Nice detailed
Over 30 M-cars
      06-14-2015, 10:48 AM   #8
mhkm
The Doctor
mhkm's Avatar
14
Drives: 2007 E92 335i; 2013 E70 X5M
Good write up supplemented with nice pics!
Thanks for contributing.
2007 335i: Evolve tune, AR Catless DP, VK FMIC, Vorsteiner lip, VRS CSI bootlid, Lux V3, RD strut bar, P3 Boost guage, PSW, BMW Performance Power Kit, Injen intake - TOTALLED by son
2013 X5M: VRS lip, Velos Tune, Catless DP, Dome hood, electric trailer hitch, performance alcantera SW.
      09-18-2015, 06:04 PM   #9
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
I haven't used my endoscope to look inside the heads yet, but the 3rd spark plug on the drivers side was still wet with fuel. All much injectors are Index 07 so once again I'm just going to consider this as an upgrade for more power, better mileage and no more soot on my tailgate.
As for the spark plug tool, I bought one eBay for $20 to find out I could have gotten it at my local Sears for $6.
http://m.sears.com/cta-manufacturing...SPM11205436019
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      10-19-2015, 09:42 PM   #10
m5james
m5james's Avatar
Can you verify which plugs you installed and where? I'm trying to determine the differences between the ZMR5TPP33 @ $25 vs ZR5TPP33 @ $9 which through realoem.com cross reference between each other anyways.
      11-17-2015, 02:20 AM   #11
m5james
m5james's Avatar
Bump
      11-20-2015, 01:50 PM   #12
WallyM5
WallyM5's Avatar
42
Call Bosch directly, I spoke with their guys and it was my understanding the M was just private labelled for BMW.
      11-20-2015, 08:18 PM   #13
m5james
m5james's Avatar
I wouldn't be surprised, but until I can get this "Reduced Power" message to go away, I'm gonna pony up the $17 per plug (buddy is giving me his employee discount) vs $9 on eBay. I'm also borrowing another buddies smoke machine, so hopefully I find something to finally remedy this nagging issue that's yet to have a concrete answer when I search the forums...I can't even figure out what this first code is.
      11-22-2015, 05:35 PM   #14
m5james
m5james's Avatar
$140 later thanks to my buddies BMW discount since he's a tech there and I've got factory ///M plugs. He said he compared them and that they're a heat range colder and are longer than N63 plugs.
      03-31-2016, 09:16 PM   #15
novablackm3
how often do we need to replace the spark plugs?
      04-20-2016, 11:35 AM   #16
YuCrew
Drives: N/A
Spark plug torque
This is an excellent write-up.
Does anyone know why there is a different torque value for the spark plugs depending on whether you're using a 6 point socket vs a 12 point socket?
A very responsive dealership told me "If it is a 6 point [socket] then 30 newton meters ... if 12 point [socket] then 23 newton meters"
I would appreciate an education/explanation on this from anyone who cares to take the time to teach me. Thanks.
PS: I understand that you can generally apply substantially more torque without stripping with a 6 point than a 12 point, but since this BMW spark plug probably doesn't work with most 6 point sockets and doesn't require absurd torque to seat properly, I consider the 30 Nm spec irrelevant in this case/application. Still doesn't make complete sense to me. Can't imagine you would torque a lug nut to a different spec depending on number of sockets points.
      04-20-2016, 11:41 AM   #17
m5james
m5james's Avatar
Just an FYI...got a return call from Bosch and they said the ZMR5TPP33 plugs are installed from the factory, after that their books show using the ZR5TPP33 after that. Good thing I got my plugs for cost but I'll be buying on eBay for next to nothing from here on out.
      04-20-2016, 11:49 AM   #18
X Driver
X Driver's Avatar
Switzerland
70
Drives: X5M Black Fire Edition
A very responsive dealership told me "If it is a 6 point [socket] then 30 newton meters if 12 point [socket] then 23 newton meters"
For me this make no sense, 23Nm is correct, no matter which socket you use..
      04-21-2016, 08:12 AM   #19
YuCrew
Drives: N/A
BMW Spark Plug Socket
Hope this helps someone ... lots of these sockets on ebay but generally long ship time from Asia.
I found one on Sears.com, free shipping from within the USA for $6.99. My order shipped the day after I placed it. (Although this is not as good a price as the $5.38 price shown on the link further above, but does not including shipping)
Description Item # SPM12152107130 Model # 4375
ABN Thin Wall 14mm 12-point Spark Plug Socket BMW 3/8 Inch Drive
The ABN Thin Wall 14mm 12-point Spark Plug Socket BMW 3/8 Inch Drive is a must have tool. Designed for BMW engines, but also works perfect for some Nissan, Toyota engines. Constructed from Chrome Vanadium Steel (CR-V) for added strength and durability. Designed with metal retainers to keep plug inside the socket during install and removal. Specifications: 3/8-inch drive, 12-point, 14mm. Overall length of 2-1/2 inches.
      04-21-2016, 08:32 AM   #20
mirob
mirob's Avatar
Drives: M3CX
This is where I got mine.
http://www.amazon.com/CTA-Tools-2376...ilpage_o02_s00
      04-30-2016, 03:12 PM   #21
novablackm3
Called a few local dealers and a Indy shop
Local shop $650 -OEM plugs
BMW Fairfax - $760 - 2.2hr labor
BMW Alex - $900 !!!!!
Unreal
      05-01-2016, 01:18 PM   #22
m5james
m5james's Avatar
Buy the $5 socket and do it yourself, it's like a 2hr job even with beer breaks lol
