      04-08-2012, 04:36 PM   #1
NANDOM5
Drives: BMW X5M E 70
2009 BMW X5M  [0.00]
Talked with Nathalie from ESS. HHT ordered!!!
Hi up, guys!!!
Finally i decided to go with ESS team. My local tuners don't seem to be able to modify my car and i want a safe and reliable mod and i found it overseas... !!!
What i want to check with them is some of this points:
"The ESS E-Flash OBD2 programming system allows the end user to upload the ECU tuning software directly to the car from any PC running Windows XP or newer. The system also includes full diagnostic and code clearing capability. Any future ESS software updates can be received by email and loaded directly to the car. The stock ECU software will be saved and can easily be restored in the future.
You will use the cable to read out the stock file, email this file to us (remember to write down car type, exhaust etc.) and you will in return get a new file which you will upload to the car..."
My only experience on hand held tuners was with COBB, but the steps were different. I received the device, uploaded my ECU stock file into the same advice, then i downloaded it into the PC, and then i ran my car to Log the different engine parameters. After all, i sent the logs to them and finally received a personal and custom tune, only for my car...
What i see here is they send me a tune directly from my stock file, isn't it??? Don't they need my datalog concerning AFR, Knock sums, Fuel, Boost...??? Am i getting dizzy???
Regards!!!
