      09-24-2017, 01:11 PM   #1
silverfox
Alpine White M Performance
37
Drives: 2013 X5
2013 5.0 Performance lowered on H&R
Drives a little harder with a hint of bounce going over bumps.
      09-25-2017, 11:40 AM   #2
jiggz
Drives: E90 M3|F15 X5 50i
I bet - it looks pretty low! How much of a drop?
      09-25-2017, 03:15 PM   #3
silverfox
37
Drives: 2013 X5
      09-26-2017, 06:07 PM   #4
pers785
Drives: 2013 X5M
More pics!!
      09-29-2017, 08:28 AM   #5
silverfox
37
Drives: 2013 X5
[IMG][/IMG] Im going to see if the front settles a bit over the next week. Might raise the rear up just a tad. This corners with such little body Roll now. Definitely gives it a sinister look imo. In the process of refinishing my wheels to a gloss black. 12 & 15 mm spacers going on afterwards.I will be sure to get before & after pics.
      10-08-2017, 11:45 AM   #6
silverfox
37
Drives: 2013 X5
Wheel 90% sanded & prepped on the car
      10-08-2017, 11:49 AM   #7
silverfox
37
Drives: 2013 X5
Front wheels primed, painted gloss black with gloss finish.
      10-13-2017, 11:46 AM   #8
silverfox
37
Drives: 2013 X5
Calipers Sanded Ready for primer
      10-13-2017, 12:47 PM   #9
silverfox
37
Drives: 2013 X5
Cleaned with vinegar, wiped clean now lets apply some primer.
      10-13-2017, 01:19 PM   #10
silverfox
37
Drives: 2013 X5
Ready for some paint
      10-13-2017, 02:03 PM   #11
silverfox
37
Drives: 2013 X5
Letting dry then M Decal & Gloss Coat
      10-13-2017, 03:40 PM   #12
silverfox
37
Drives: 2013 X5
12MM spacers on up Front & 15mm in the rear. Happy with both my wheels and calipers. Downpipes & Tune for my M Performance next.Adjusted my end links on rear adjustable suspension and it drives perfect! I used 3 coats of primer, paint & gloss for both wheels & calipers.
      10-13-2017, 08:19 PM   #13
BimmerBoy78
BimmerBoy78's Avatar
Drives: 2015 BMW X6M F86
Looks good, keep up the great work!
      10-13-2017, 09:48 PM   #14
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
1) Unless the 5.0 is different than the X5M, I'm pretty sure they only make 1.2" & 2".
2) Your stickers are upside down, they should be flipped over so they're read the same way as the BMW letters are factory stamped on the calipers.
Looks good though :-)
      10-14-2017, 10:10 AM   #15
silverfox
37
Drives: 2013 X5
[QUOTE=m5james;22303752]1) Unless the 5.0 is different than the X5M, I'm pretty sure they only make 1.2" & 2".
Yes 2. Thanks for pointing that out. Doing my wifes 335 next So I will get it right
