      11-16-2021, 09:50 AM   #1
hollower
Drives: E71 X6 M
Car is Sluggish
I need help, i bought a X6 M from a pawn shop, i drove it around everything seemed fine, but after a while when i tried to put my foot down there was a check light "Engine Malfunction: reduced power" i took it to a mechanic, there were some compression faults, that i fixed by changing destroyed tubing. its no longer putting out a check light, but it feels sluggish, it really doesn't feel like the car has 555 horsepower. the turbines are in great shape no damedge and no oil leaks, the start is neck breaking but 0-60 mph is 7 seconds and it takes forever to pick up speed. i need help what could be causing this, i even reset the transmission but no luck, i need help
      12-10-2021, 09:40 AM   #2
1er_vert
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
You need to scan it fully on ISTA.
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      12-14-2021, 12:43 PM   #3
Bilbofraggins
Bilbofraggins's Avatar
Drives: 2013 X6M, 2019 X3 M40I
X6Ms don’t like old gas…I have played around with that issue a few times, always after the vehicle wasn’t driven for a few weeks.
I always fill the tank before I go away - if I leave it at say a quarter, I know that if I don’t drive sedately to the gas station on return, the reduced power malarkey will appear.
      12-22-2021, 04:52 PM   #4
1er_vert
Piezoelectric high-precision injectors get very gunked-up badly. I bet the pintle head and shaft is black as coal. Gumout Regane with PEA will clean it out, after three treatments.
zhangyi17286.50
