      12-22-2019, 08:47 PM   #1
Napco
Drives: 2013 BMW X5 Premium
Valvetronic Servomotor Fix?
Has anyone ever successfully just replaced the wire loom on the Valvetronic Motor without having to replace the internal costly and expensive Valvetronic Servomotor parts? I scanned three times with ISTA-D and found these codes. 002DD6 and P10E2 Thank you for any direction.
Last edited by Napco; 12-22-2019 at 08:55 PM.. Reason: Forgot to add the error codes.
      12-28-2019, 09:21 PM   #2
pjfox23
Drives: X5 35i, X5M
I'm pretty sure the second code is for the sensor.
Sensor is more likely to fail than the actual motor. What is making you ask that question?
Napco0.00
      12-29-2019, 12:39 PM   #3
Napco
Thanks for the reply,
Do you have any experience with ISTA-D/P and also can I ask why you think the second code is for the sensor?
      01-07-2020, 06:24 PM   #4
Napco
Valvetronic Servomotor Wire Loom Replacement
Well, unfortunately no help replacing the wire loom at the Valvetronic Servomotor.
Scanned again with ISTA-D and this same fault error code is present. 002DD6 and SAE Code P10E2 the reading on the Valve Angle 179 Grad.
Vehicle condition is the same "Crank no Start"
Looks like time for the "Stealership"
      03-24-2024, 12:51 PM   #5
X5boyz
X5boyz's Avatar
Drives: 2013 x5
Can someone help I知 getting this code on my2013 x5 35i
I知 really not to experienced when it comes to bmw and before I throw out a bunch of money does anyone have any advice they can share
002e0f
Valvetronic system, deactivated, adjustment fault too frequent
EWS (Electronic Vehicle
      03-24-2024, 01:05 PM   #6
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
002e0f
Is it a current code, or an older saved code? Delete it and take for a drive, see if it returns? If it is current/returns, sounds like a communication error rather than mechanical.
      03-24-2024, 01:14 PM   #7
X5boyz
X5boyz's Avatar
Drives: 2013 x5
No it痴 a new code also the car drives good it痴 more noticeable when I知 at a light the car would like rev
      03-24-2024, 03:00 PM   #8
StradaRedlands
2006 Mazda3  [5.50]
You've probably already seen this post, but it lays it out pretty well... either the motor itself or some wiring: https://www.e90post.com/forums/showthread.php?t=1536073
