      01-19-2013, 03:30 PM   #1
nachilus
Drives: 2007 x5 4.8
E70 Spacers
Have anyone installed spacers and bolt kit from ECS Tuning?
If so any feedback?
http://www.ecstuning.com/BMW-E70-X5_...ers/ES2550799/
      01-19-2013, 11:18 PM   #2
Devimik
Devimik's Avatar
Drives: 2018 X5 35i Sports Activity
I haven't used ECS spacers, but I've used Macht Schnell spacers from EAS on my M3 and on my e70. The wheels I bought for my X5 had the 72 mm centerbore and the e70 has a 74mm centerbore, so I had to get 20mm spacer adapters and they work fine.
Looks better, in my opinion, as the wheels are pushed out 20mm so as not to have that tucked in look given the rear tires are smaller than stock.
I would think the ECS ones would be fine to use - I would not have any concerns about them.
Here's a pic with the 20mm spacers and bolts.
      01-20-2013, 08:49 AM   #3
nachilus
Drives: 2007 x5 4.8
Thanks for the response, I am now thinking of getting 25mm.
I don't know if it will fit properly.
      01-20-2013, 10:01 AM   #4
n3985
Drives: a car
Just go measure the distance from tire to fender then, just make sure to buy the appropriate extended bolts.
      01-20-2013, 11:06 AM   #5
Devimik
Devimik's Avatar
In my pic, the wheels are 20X10" and the offset is 40mm. The tires are 275/40-20, which is stock size for the fronts, but the back was 315/35-20. The stock offsets are 40mm front and 27mm rear, so a 20mm spacer on the front pushes them out further than stock, but on the rear, not so much.
      01-21-2013, 10:38 AM   #6
daltonnnn
Driver
daltonnnn's Avatar
Drives: F80 M3, MSM, Clubman S
I just ordered 12.5mm fronts and 20mm rears for my stock 20" wheels, which came in a few days ago. I think style 214 (the ugly flowery ones). Was thinking about installing them today, but I doubt I have time, so next weekend.
** Go Navy! **Go SF 49ers!!!** Go SF Giants!!! Go Warriors!!!!!**
      01-21-2013, 11:44 AM   #7
nachilus
Drives: 2007 x5 4.8
Here are you getting them from?
      01-21-2013, 08:57 PM   #8
rh71
rh71's Avatar
Drives: '08 X5 3.0si
bought H&R spacers with the extended bolt set from Turner Motor Sports. Talk to someone on the phone and they'll get you the right set.
'08 X5 3.0si - Alpine White -> more pics <-
      01-21-2013, 09:17 PM   #9
skunkd
skunkd's Avatar
18
Drives: 2004 STI 2008 BMW M5 2004 530i
I have 12mm front and 25mm rear. Go with the 25 in the rear. The fitment is perfect 20 probably isn't enough
      01-21-2013, 09:48 PM   #10
nachilus
Drives: 2007 x5 4.8
I spoke with someone at ECS tuning, and i bought the 25mm H&R for the rear.
      01-21-2013, 10:02 PM   #11
speedwaywhite
Drives: 2011 X5M, Sapphire/Perf.Bambo
Awaiting pics
      01-21-2013, 10:04 PM   #12
nachilus
Drives: 2007 x5 4.8
Originally Posted by speedwaywhite View Post
Awaiting pics
I will add before and after picts as soon as i get them.
They should be here by friday.
      01-22-2013, 10:49 AM   #13
finagle69
Drives: '08 X5 4.8i
I have 12mm front and 20mm rear spacers from ECS. They went on perfectly and have no vibrations to speak of.
      01-22-2013, 07:03 PM   #14
daltonnnn
Driver
daltonnnn's Avatar
Mine are from ECS.
      01-22-2013, 07:37 PM   #15
nachilus
Drives: 2007 x5 4.8
Mine are from ECS.
any picts?
      01-26-2013, 09:01 PM   #16
nachilus
Drives: 2007 x5 4.8
I installed the spacers today, sorry for the dirty vehicle.
We had a little messy snow yesterday. I will take a full stance and better picts tomorrow.
This is the H&R 25mm I got from ECS Tuning. These are 20" (214 bmw Wheels)
      01-27-2013, 09:08 AM   #17
APLINE_997
Drives: 997 Turbo
Any updated pics when get have a moment I was thinking 15 front and 20mm in the rear. Maybe I will go 25mm. Have to raise the rears a little. It is a little too low.
      01-27-2013, 09:41 AM   #18
nachilus
Drives: 2007 x5 4.8
A friend of mine added 20mm and it was still a little tucked.
Also the 20mm uses longer bolts that passes through the wheel and the spacers.
The 25mm comes with its own bolts that goes to the hub and the wheels bolts into that.
I will update pictures today or tomorrow.
      01-27-2013, 10:45 AM   #19
APLINE_997
Drives: 997 Turbo
Nachilus - thank you for the update. I was trying to keep my car stock and leave everything alone due to my mod bug for my other cars. Just had it lowered and it appears more tucked in with it lowered so I have to add spacers right?
I will get the 25mm then. Did you run any in the fronts? Thoughts on 15mm? or would 12mm work?
      01-27-2013, 01:55 PM   #20
nachilus
Drives: 2007 x5 4.8
I did not add any to the front yet. I will order next week.
I am looking at 12-15mm I will measure and update.
      01-27-2013, 02:50 PM   #21
Sylvan Lake V35
Vanilla Gorrilla
Sylvan Lake V35's Avatar
Drives: X5M & X5 35d
So you are running 20mm spacers all around? I was planning on getting these wheels for my summer wheels but I was hoping they would be a little more concave
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
      01-27-2013, 06:54 PM   #22
skunkd
skunkd's Avatar
18
Sylvan,
Look up the "XO Miami" wheel they have x5 fitment and are super concave (like vossen cv-3) priced friendlier as well
