      06-06-2018, 07:35 PM   #1
Xfanatic
Drives: 2014 X6 5.0i
Downpipes for 2014 X6 5.0
I want to add downpipes for my 2014 X6 5.0. I'm having trouble finding an option with the correct connection method. Originally I was going with Racing Dynamics but they have the flowing note
https://www.racdyn-usa.com/PROD/130+10+63+220.html
Special notice!
BMW made 2 different downpipe connections: flange and slip fit. Before purchasing you need to verify which connection you have. Look underneath your car where the downpipe connects to the exhaust and see if you have a bolt together flange or slip fit with compression clamp. This model is for bolt together flange connection.
After checking with my shop my vehicle has the slip fit connection. Does anyone know of a manufacturer that has the nessary slip fit connection?
I know there are threads on here where people have gutted the original pipes but that's a last resort for me.
Thanks for the help.
      06-06-2018, 09:49 PM   #2
Bmf007
Drives: 2013 bmw x6 35i
Vrsf
      08-09-2018, 03:20 AM   #3
urabus040
Drives: 2014 X6 I35
2014 BMW X6  [0.00]
Ditto....vrsf maybe try turned motor sports as well? I got my DP from VRSF and couldn't be happier
      08-10-2018, 10:15 PM   #4
9vapors
Drives: CB X5M
As it was recommended to me today, put your last 7 in realoem and look at the exhaust section. Should show which you need.
      01-08-2019, 10:54 AM   #5
MehdiMost
Drives: Individual
Fuel consumption
Hi guys
I recently bought X6 50 (E71)
and i think it use consume fuel too much
around 8 mpg us
I check the diagnostic but it didn't have any errors
anyone has this problem and experience?
      01-08-2019, 05:10 PM   #6
mrsoandso
mrsoandso's Avatar
9
Drives: '11 X6M
Originally Posted by MehdiMost View Post
Hi guys
around 8 mpg us
You have to make a few posts before you can make a thread.
This forum https://www.xbimmers.com/forums/forumdisplay.php?f=94 will be a better place for your question. Also the X5 shares many parts with the X6, and I've often found more info in the X5 forum for my queries.
