      05-09-2018, 01:40 AM   #1
dalija
Drives: X6M
X6M coldstart missfire
Hello,
My X6M has a problem, when the engine is cold. the engine will not run at all cylinders and it gets some missfire's.
i already changed spark plugs and ignition coils. reseted lvs. adaptions etc...
when the engine is hot, i dont have any problems.
error code:
2B1C: combustion misfires cyl. 7
thx for help
      05-09-2018, 08:50 PM   #2
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
You NEED new injectors, you literally also need to stop driving the car as flooding the engine with fuel can hydrolock it...GF's engine shattered piston #1 from the same issue. They're a recall item so you'll get a loaner but you might be stuck getting it towed there yourself.
      05-11-2018, 03:58 AM   #3
dalija
Drives: X6M
should i switch one injector to other cylinder, prog dem on ecu and then check if the error switches to other cylinder? if it switches, than its 100% the injector
      09-18-2018, 03:02 PM   #4
Tony Mackelve
Drives: x6
Hi guys i realy need help with my x6e71 its refusing to idle for more than 20 minutes or to drive , it switches of , i called many technichians they cant find fault , i being buying parts like crank sensor , pressure sensors etc but no joy . now they saying high pressure regulator pump and injector ? please advise .
      09-18-2018, 03:10 PM   #5
m5james
m5james's Avatar
Help us help you...edit your post so it makes sense and give more details as to what's happening past these 20 min.
      09-18-2018, 03:32 PM   #6
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
No, you cannot just sway injectors. Coils and Plugs yes. Injectors are covered, get the car to the dealership.
      09-18-2018, 03:33 PM   #7
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Tell them to perform the recall maintenance on the injectors. 1 thing at a time.
      09-18-2018, 03:47 PM   #8
m5james
m5james's Avatar
Yes, you can swap injectors so long as you code them as well. What Staten is saying is that the injectors are covered under a BMW recall.
      09-23-2018, 04:19 AM   #9
Mightymaus
Mightymaus's Avatar
Drives: Graphite/Black leather X4 M40i
2012 X6 M  [0.00]
Are you using 92 octane fuel or better? Changing to a higher octane fuel at this point won't fix the issue but, if you're not using good fuel and the recommend octane then you Will have issues with preformace regardless of the ping sensors on the engine.
