      06-14-2018, 08:13 AM   #1
philly42
Drives: X5M, Z3M
Lowering spring w/ shorter bump stop
I'm thinking about getting H&R 1.2" lowering springs. Has anybody shortened or replaced their bump stop for this setup? Dinan sells bump stops for their lowering springs. Though they might not work well with H&R since it provides a lower ride than Dinan.
Also any pics of H&R 1.2 on stock 20's?
      06-14-2018, 07:49 PM   #2
socale39
Drives: 04 545i SMG
Dinan bump stops are a waste of money. With that drop I would only recommend cutting the rear bump stop for times when the SAV is fully loaded.
      06-14-2018, 09:32 PM   #3
9vapors
Drives: CB X5M
You’ll have to search for it, but the Dinan bumpstops are actually oem bumpstops from an M5 if I remember correctly. Someone took the part number from them and looked them up, same part number, just about $70 less.
Here is the thread where you can see pics and discussion about the springs...http://www.xbimmers.com/forums/showt...=775997&page=3
      06-15-2018, 04:29 PM   #4
philly42
Drives: X5M, Z3M
Yeah the Dinan bump stop are way over priced and are just from the F10 M5. When I do the lowering springs, I'll install new bump stops.
