      05-24-2018, 11:02 AM   #1
Yanchii
Moldova
59
Drives: 09 BMW X5 35D
Water leak.
Can anyone point me in the right direction, when it rains or I wash the car I have water coming into the passenger floor board on my X5. I have checked to see if it's the sunroof and it's not clogged, What else could it be?? it only happens when it rains or I wash the car??
      05-24-2018, 11:27 AM   #2
carbonM
Drives: 2011 E70 50iMt, 2011 e82 135i
So I had a similiar issue with my e53 X5. Everyone was saying it was my sunroof drains but I wasn't convinced. Turned out that the seal around my windshield was leaking. I figured this out by taking a hose and pour water starting at the lower part of the windshield, then checking for leaks. Move higher and higher with the hose until you start seeing leaks. This will help you isolate where the leak is actually at.
      05-24-2018, 02:58 PM   #3
rodnex
Drives: E70 3.0si, E70 3.0d, E70 X5DUS
Maybe the rain drainage under the ECU box (located under the aircon air cleaners) is clogged?
      05-24-2018, 06:29 PM   #4
Yanchii
Moldova
59
I will give that a try thank you!
      05-24-2018, 06:30 PM   #5
Yanchii
Moldova
59
I didn't even know something like that existed but I will look into that! thank you !
      05-25-2018, 10:40 AM   #6
cbakking
Drives: E70-X5M
I would love to see these drain hole's locations, if anyone has pictures or diagrams?
Sunroof drain, ECU Box drain?
      05-25-2018, 12:53 PM   #7
Yanchii
Moldova
59
Same here! sunroof drain holes are in all four corners of the sunroof, I'm curious as to where the others are!
      05-25-2018, 03:50 PM   #8
Yanchii
Moldova
59
[IMG]undefined[/IMG] well I now know why water comes in, looks like the last shop forgot to put the filter and housing back....
      06-12-2018, 04:42 PM   #9
rodnex
Well at least you noticed on time... before the blower motor went belly up. Hope they still had the leftover parts...
