      05-03-2018, 09:57 AM   #1
carbonM
Drives: 2011 E70 50iMt, 2011 e82 135i
Coolant leak drivers side
I woke up to this morning to a coolant leak under my X5 50i. I didn't notice it leaking when I parked it last night so not sure when it occurred. I popped the hood and found coolant around the reservoir tank.
I thought it maybe leaked out of the cap area. Checking the level it was just below the min. There was coolant on the underside of the hood, so there was enough pressure to make it splash up. I started up the car, let it warm. Didn't see it leaking at all.
I pulled the car forward, leaving it running and looked under the car to find it leaking pretty good, created a small pool. I moved the car back into my parking spot and it wasn't leaking like it was before.
I drove around the block twice to see if I left a trail of coolant which I did, but when I looked under the car is wasn't leaking at that point. I looked under the hood again but didn't see anything leaking.
      05-03-2018, 10:49 AM   #2
carbonM
*Update*
I think it might be the reservoir tank leaking. Looking down at the bottom of the tank where the lower coolant hose attaches, it looks really wet around the connection.
      05-03-2018, 04:01 PM   #3
carbonM
I inspected it further and found its leaking out of the cap into the overflow hole. It's hissing and bubbling in that hole. Maybe just a bad cap?
      05-03-2018, 05:13 PM   #4
werdn
werdn's Avatar
656
Drives: 997.1 GT3 Shark, ex E92 M3 ZCP
The exact same thing happened to me. The first thing that I did was replace the cap. However, that didn't really work, so I DIYed the whole tank. After that no more leaks!
So try replacing the cap first.
      05-12-2018, 12:44 PM   #5
carbonM
So the expansion tank had a leak in the overflow hole area. I replaced the tank with a geniune BMW expansion tank and cap. The quality of the new tank seemed a lot better than original and the alignment arrow is painted yellow so that you know the cap is secured. Here is pictures
Old
New
      05-14-2018, 06:14 AM   #6
Lunker325
Drives: E70 X5M / 991.2 C4S
Thanks for sharing and updating us with the fix, good info.
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune
      05-14-2018, 07:09 PM   #7
Birdoprey
Drives: 2013 X5 50i M Sport
Old
Attachment 1823231
New
Attachment 1823232
Where did you buy the tank from and how much was it?
2013 X5 50i-M Sport w/ Dinan Stg 2 tune
      05-15-2018, 04:32 AM   #8
Mickeytl
Drives: 12 BMW X5 xdrive 50i
Glad is fix
      05-15-2018, 10:33 AM   #9
carbonM
I bought it from getbmwparts.com for $100. Service is good and they usually always have parts in stock.
      05-16-2018, 08:25 PM   #10
Birdoprey
Thank you sir!
      05-17-2018, 11:23 AM   #11
cbakking
Drives: E70-X5M
How hard was it to replace it? DIY? do you have to drain whole coolant? or just the coolant in expansion tank?
      05-17-2018, 01:36 PM   #12
carbonM
It's really simple. You will lose some coolant. I don't reuse coolant, but I had to put about a gallon in.
1. Leave the tank cap on.
2. Disconnect the upper hose on the tank.
3. Unscrew the two bolts holding the tank.
4. Unclip the plastic vacuum tube running next to the tank.
5. Unclip the coolant level sensor on the bottom of the tank.
6. Unclip the lower tank hose. Right when you remove the hose, put your finger over the hole on the tank to keep it from draining. Pull the tank out and drain in bucket. You will get more room if you remove the plastic air intake tube.
7. I then put a rubber cap on the radiator host to stop it from draining to much.
8. Put in the new tank and reconnect the level sensor and lower hose.
9. Bolt the tank back down with the two screws.
10. Reconnect the upper hose.
11. Mix 50/50 distilled water and coolant. Fill the tank to the min level and put the cap on. I also checked the coolant level in the intercooler tank as this time.
Start up the car, check for leaks. Drive it around and get it to operating temp. Then once it cools, check the expansion tank level again as it probably will need some additional coolant to bring it back to min. level. DONE!
      05-17-2018, 01:41 PM   #13
cbakking
Drives: E70-X5M
AWESOME!! thanks for the info!!
      05-17-2018, 08:55 PM   #14
omgboost
Drives: 2012 X5 35i
When you do work like that to the coolant system, don't they recommend you bleed the system of air?
      05-18-2018, 11:06 AM   #15
carbonM
Good question, there is a electric pump coolant bleeding process, but I have never gotten it to work unless the inter-cooler coolant tank has been low.
How to bleed the system using the electric pump process.
1. Connect battery charger.
2. Switch on ignition.
3. Set heater to maximum temperature (set to "Automatic"), turn fan to lowest setting.
4. Depress accelerator to maximum for 10 seconds. The engine must not be started.
5. The bleeding sequence has been started by depressing the accelerator and takes about 12 minutes. (The electric coolant pump has been activated and switches off automatically after about 12 minutes.)
6. Afterwards, fill coolant expansion tank to 250 ml above "Max". (Observe service instructions specific to vehicle.)
7. Check cooling system for leaks.
8. If the bleeding sequence has to be repeated (e.g. if there are leaks in the cooling sys- tem), allow DME to reset completely (remove key from ignition for about 3 minutes), then repeat procedure from step 3.
      06-04-2018, 11:52 AM   #16
cbakking
Drives: E70-X5M
My coolant expansion tank finally gave away, pool of coolant around driver side front wheel, with carbonM's direction I was able to replace it with ease... but now I've gotten CEL? started with warning message "Please tighten the gas cap" while I was driving so pulled over double checked the gas cap and it was fine and continue to dive then CEL came up along with warning message "Please tighten the gas cap".....
Now I wonder it could be simple as old gas cap - easy fix- but wonder if coolant leak somehow damaged EVAP valve? any help would be appreciated!
      06-04-2018, 12:40 PM   #17
carbonM
Now I wonder it could simple as old gas cap - easy fix- but wonder if coolant leak somehow damaged EVAP valve? any help would be appreciated!
Could be a bad gas cap. Did you check for damaged vacuum lines near the coolant tank? How long have you been driving it since you checked the cap tightness? I know it can take some driving before the code will clear on its own.
      06-04-2018, 02:31 PM   #18
cbakking
Drives: E70-X5M
Just ordered the new gas cap, hope it's just simple gas cap issue but I have feeling it's something else like purge valve since it's too coincidental warning message right after replacing coolant tank..... crossing my fingers
      06-06-2018, 10:35 PM   #19
9vapors
Drives: CB X5M
I got this CEL after using some bad gas.
      06-07-2018, 12:26 PM   #20
cbakking
Drives: E70-X5M
Tried new gas cap and still got "Please tighten gas cap" message along with CEL, took it to indy the other day, they said I've got leaky fuel breather hoses that need to be replaced, they had to order them so still pending the final results, we'll see if new fuel breather lines are going to fix the CEL.
      06-14-2018, 11:53 AM   #21
cbakking
Drives: E70-X5M
All fixed with new fuel breather lines replaced, but got quick question regarding coolant bleed "How to", when you go thru this steps, does the coolant cap need to be opened or closed? and will this steps bleed inter-cooler coolant as well?
      06-14-2018, 12:30 PM   #22
cbakking
Drives: E70-X5M
Found this, it sounds like cap needs to be closed during this procedure:
https://www.newtis.info/tisv2/a/en/e...check/CMAxpWPX
Venting cooling system: Note:
Do not leave the coolant expansion tank cap open during the venting procedure.
1- Open vent plugs on coolant feed lines to turbocharger.
2- Add coolant up to top edge of expansion tank. Coolant level must not drop further! No drop in coolant for approx. 1 minute. Close vent plugs on turbocharger when coolant emerges.
3- Set heater to maximum temperature. Press Automatic button. Then turn blower down to lowest stage for a minimum period of 5 minutes.
4- After switching off heater pump, add further coolant up to top edge of expansion tank.
5- Check cooling system for leaks.
6- Close expansion tank.
7- Start engine. Allow engine to idle for approx. 1 minute. During this period, press accelerator pedal 3 times (each time lasting 5 secs.) to approx. 3000 rpm.
8- Warm up engine and activate map thermostat via BMW diagnosis system.
9- When engine has cooled down, check coolant level and adjust to max.
Not sure about step 1? what's vent plugs on coolant feed lines to turbocharger?
Tags
n63 coolant leak
