01-17-2018, 03:48 PM | #1 |
Rep 1,727
Parking Brake Issue
Hey all -- searched but couldnt come up with a response.
When i engage the parking brake on my 2012 X5M, it holds well until i turn off the engine. then it seems the car lurches forward and settles again. Is there a way to test if the brake is holding? What could be the issue?
2017 C63 2012 X5M SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i |
01-17-2018, 04:38 PM | #2 | |
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
01-17-2018, 04:45 PM | #3 |
Rep 1,727
Interesting. and it only started after i replaced the brake pads
01-17-2018, 11:03 PM | #4 |
Rep 336
Drives: 2010 BMW 335d
Garage List 1984 Dodge Ramcharg ... [0.00]
1988 Ford Bronco 351 [0.00] 2002 BMW e39 540i S ... [0.00] 2010 BMW 335d [0.00] 1997 Husaberg FC600 [0.00] 2010 X5 35d [0.00] 2015 Can-Am Outland ... [0.00] 2004 Ford F350 Supe ... [0.00] 2014 Ford Edge (Com ... [0.00] 2014 John Deere D130 [0.00] 2010 John Deere JS46 [0.00] |
Normal. The DME holds 4 wheel disc braking while the engine is running, switches to a mechanical rear parking brake shoe when turned off. There are adjustments you can perform, but may not improve the behavior. Be sure to always engage parking brake before shifting in park on all vehicles to prevent transmission parking pawl wear.
01-18-2018, 10:09 AM | #5 |
Rep 449
Parking pawl wear isn't a modern failure people have to worry about, in the real world.
In theory yes, it is a great idea.
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD 1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about 1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter |
01-19-2018, 01:39 AM | #6 |
Rep 336
Beg to differ on that one.
01-19-2018, 07:37 PM | #7 |
i'm just saying
5764
Rep 2,634
its because as its said to switch into mechanical hold.. car needs to roll a bit to lock it properly.. its weird.. i never seen such a thing in any car i drove.. i dont know why BMW likes complex things this much.. when parking on incline narrow places there is a way to make less dangerous to hit another car.. after stopping putting it in N to get rid off torque converters push then parking brake.. then car rolls less.. "generally"..
01-23-2018, 10:16 AM | #8 |
Rep 449
So you have had a bunch of parking pawl failures? I have honestly never seen one single failure, ever, and I have spent more then a few years working at dealers, and currently have a fleet of vehicles I am supporting, and yet, not one single failure.
I know they are out there. If you could explain maybe I would understand
01-23-2018, 10:58 AM | #9 |
Rep 291
Same thing is happened to me and it doesn't seem normal
However I've noticed the car barely moves after the car is off, if you use "Auto H". The green auto H light will turn to a red park when you turn off the car and there will be minimal movement. |
01-23-2018, 01:26 PM | #10 | |
Rep 336
https://estimate.myautomatictransmis...-parking-pawl/ |
01-24-2018, 09:54 AM | #11 |
Rep 449
That's wrong. If that is what has swayed you over to thinking that a parking rod or pawl is not designed to hold a vehicles weight, then I hope to persuade you otherwise.
There are more people with automatics that do not use a parking brake then people who have automatics and do, so why are they not seeing failures? Being as the parking pawl is holding the weight of the vehicle in the majority of those applications, why are there parking pawls not failing? I think you will only see parking pawl failure if you have a car that you can manual activate park, and you slam it into park at a high rate of speed. I tried to find something in the Ford operators manual in regards to parking pawl, the only thing they state on the park selection is, "Park (P) This position locks the transmission and prevents the rear wheels from turning." I can't seem to find any reference to the parking pawl holding a vehicles weight. I looked through our owners manual and it doesn't specifically say anything on the issue, though they state the parking brake should be set with the vehicle parked Please also keep in mind I have seen the worst of the worst coming through the shops I have worked at, and personally have not seen a failed parking pawl. I also want to let you know I mean no offense, or ill will towards you, this kind of 'debate' just intrigued me.
fsd35054.50 |
01-24-2018, 10:56 AM | #12 |
Rep 310
Agreed with above that the roll is a because of the car switching from abs hold (normal brake) to mechanical rear brake drum (parking brake). If you can feel an obvious roll before the parking paw (inside transmission) holds the car, it is a sign that the parking brake needs to be adjusted.
It is a simple diy if you are mechanically inclined (search e70 parking brake adjustment), or should be a .5 labor thing with any good INDY. Good luck |
01-24-2018, 03:03 PM | #13 |
Rep 336
No offense taken Joey, I appreciate that. Applying the parking brake before shifting to P was something I was told many years ago by one of my mentors when I was a technician. I have seen a couple pawl failures due to a customer rocking a transmission back and forth in the snow and then slamming into park. That was back in 88 when I worked for Honda, and their transaxles were less than robust at that time. We used to rebuild them back then. No issues from an incline or otherwise. I picked that article as it was the first that came up when I searched. I wouldn't want to rely on the parking pawl alone at a boat ramp for example, that's for sure. It makes sense to me to apply the brake before as a best practice, it does not create that load on the pawl and is easier to shift out. I get your point also. I have not seen any failures from normal use either.
Naz241627.50 |
01-28-2018, 10:05 AM | #14 |
Rep 709
Totally agree on it being best practice to apply the parking brake before putting in park.
Also totally agree that 98% of the population has no clue about this. I have seen one instance which was suspected to be parking pawl failure. About 22 yrs ago I had a leased pickup parked on the street in front of my residence, and a neighbor's pickup which was parked in his driveway directly across the street rolled backward and down into the side of my truck. Don't recall what make truck his was. I would think regular abuse from ignorance over time MAY result in occasional failure, but very rare. However my father-in-law NEVER uses his Exploder's parking brake and many times I have had to yank his tranny out of park when moving his vehicle in my inclined driveway.
heatmizr [Todd]
g26 i4 e40 - Clean Machine e70 X5 50i M-Sport "The Boss" Loaded e90 328i - sold e36 M3 - Gone to become a track star |
Naz241627.50 |
