      01-23-2014, 06:20 PM   #1
Zigor911
Zigor911's Avatar
Drives: 2015 M5
Looking to lower my X6 with H&R springs
Wonder if folks that have done it, run into any issues with alignment, bushings, warranty?
Thanks
      01-23-2014, 07:04 PM   #2
SouthShoreM3
Passes everything but the gas station
Drives: 2010 E90 M3
OP for what it's worth HR there have been many that are happy with the adjustments the springs have done. I have also heard that it can be at times very bumpy in he rear.
Have you looked at Dinan's suspension for the x6? For the money it's really a great mod. I have Dinan on my X5M. It may not as aggressive a drop, but it was well engineered and really made the car handle much better with no sacrifice in ride handling.
There are several threads on HR and Dinan. I suggest googling or going through the forums before making a decision.
      01-23-2014, 07:16 PM   #3
Zigor911
Zigor911's Avatar
Drives: 2015 M5
I don't believe there is Dinan suspension kit for X6 non M model - at least not listed on their site
      01-23-2014, 07:22 PM   #4
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
I would read this thread (X5 50i, same question assuming you have self-leveling) and the thread I linked in the last post. http://www.xbimmers.com/forums/showthread.php?t=931988
I'm very happy with the H&Rs myself (but there's a fair amount to the story.) No issues with alignment or suspension components - aligns within factory specs, yadda yadda.
      01-24-2014, 06:35 AM   #5
Zigor911
Zigor911's Avatar
Drives: 2015 M5
Thank you for info. The shop I talked to (they are solid bmw, merc mechanics, but not tuners ) made me think about:
1) camber and alignment. According to them, not much room for adjustment on front - only replacing arms with different minutes. Will wear tires sooner - in summer I'm on 21 inches with 325 in rear...
2) OE shocks will be compressed a bit and will be working longer in a position that were. not designed for per say - may fail sooner
3) bushings may need to be re-tightened, and/or may wear sooner
      01-24-2014, 10:19 AM   #6
FrstBmr
Drives: 2013 X6M
Here is the link to the Dinan site that has everything they offer for the X6M including the suspension drop.
http://dinancars.com/products/?series=X-series&model=x6 m-e71&mid=1136
This is what I will be doing soon to mine.
2013 X6M Carbon Black
2010 ZR1 Yellow
      01-24-2014, 11:00 AM   #7
rennis
rennis's Avatar
43
Regarding alignment, with the drop there is enough adjustability to keep it within factory specs - shouldn't see a change in tire wear with a good alignment
On #2 - probably only an issue with the front shocks - rears are air bags and shouldn't affect them. I've not seen anyone complain of premature wear on front shocks because of a drop on a X5 or X6.
      01-24-2014, 12:39 PM   #8
Zigor911
Zigor911's Avatar
Drives: 2015 M5
Right, this kit for X6M, I have X6 with rear self leveling. Not sure if it would fit
      01-24-2014, 04:38 PM   #9
Zigor911
Zigor911's Avatar
Drives: 2015 M5
Thank you for the input!
      01-25-2014, 02:22 PM   #10
rennis
rennis's Avatar
43
you're welcome. I was thinking about this thread when I was driving this morning and I will say that if anything, my feeling about the H&Rs is they feel almost too stock. I actually wish they were firmer, as I'm used to my lowered vehicles feeling much stiffer. They should have increased the spring rates, if you ask me.
If you want a drop with OEM feel and handling, these are great. If you're looking for a stiffer feel and less body roll, coilovers are the way to go. Just really hard to justify removing the air suspension and override the adaptive drive for coilovers if you ask me.
      01-25-2014, 08:21 PM   #11
Zigor911
Zigor911's Avatar
Drives: 2015 M5
Yes, agreed. H&R is what I'd go with. Everything else is overpriced overkill
      01-26-2014, 07:48 AM   #12
Zigor911
Zigor911's Avatar
Drives: 2015 M5
So, it seams getting rear right is key. Interesting to note: AC Schnitzer has lowering kits for x6, and they make different springs for v6 and v8 models (different weight - so makes sense). But they do not supply rear links - per their installation instructions, rear lowered by coding only. Their kit drops car by 30mm.
H&R has the same kit for v6 and v8 models. V8 owners report that the drop is more than advertised 1.2 inch - more like 1.5-1.8 inch which is 38-45mm.
So, coding is a must, but do I need rear links? And how adjust them if rear gets bouncy? Any suggestions? Thanks
      01-27-2014, 05:15 PM   #13
FrstBmr
Drives: 2013 X6M
My bad. I miss read it, thought you had an M.
2010 ZR1 Yellow
      03-07-2014, 08:22 PM   #14
zibo.rao
Drives: BMW X5 50i
The H&R spring wouldn't work in your rear wheels due to the fact that you have self-leveling. I think the self- leveling come with some kind of air spring in the rear. I have my X5 50i done with H&R spring at first, but it since to wear out my shocks a lot faster. Then I pair it up with Bilstein B8 shocks (the only shocks available that could fit with lower spring on an E7X), but the ride quality is just harsh. However, my combination does make it better while braking and cornering, but you will feel everything on the road. Try learn from my mistake, stay with stock set up or go with a coilover kit such as KW V3.
      03-24-2014, 02:17 AM   #15
6lacksheep
6lacksheep's Avatar
Drives: 2016 BMW X6M
Hey guys, quick question, dont want to jack the thread or anything. But does anyone know if a 2012 X6 35i has self leveling?
thanks
      04-14-2014, 07:07 AM   #16
Zigor911
Zigor911's Avatar
Drives: 2015 M5
Had the kit installed, and ride was ok... Had to visit to local dealer for different reason, and they also adjusted the height setting for rear suspension via computer - made it so much better!!! Awesome!!!
