      01-05-2014, 05:04 PM   #1
cecilcohen
Drives: 2011 X6 Alpine White
Need help with JB4 Install
How do you route the control module through the upper firewall to get under the ECU area cover?
I don't see any openings to route it under ECU cowl.
Thanks!!
      01-06-2014, 11:23 AM   #2
SteveMD
SteveMD's Avatar
196
Drives: 2016 F10 535i MSport
For an X6 or a 135?
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      01-07-2014, 08:57 AM   #3
cecilcohen
      01-09-2014, 09:18 AM   #4
cecilcohen
Damn, no one has installed this themselves?
      01-12-2014, 12:19 AM   #5
RaceTruk
Drives: F13 M6
In the edge of the cowl where the center straight portion bends/angles there is a sure in the front side.
Undo that and the 2 pieces are also double sided taped to each other, pull it apart and route through there
You can see the silver screw heads in this photo
http://en.wikipedia.org/wiki/File:BMW_X5M_Engine.JPG
      01-12-2014, 10:51 PM   #6
cecilcohen
jb4
Thanks I will attempt tomorrow.
      05-27-2014, 10:40 PM   #7
6lacksheep
6lacksheep's Avatar
Drives: 2016 BMW X6M
how did the install go? did you get it to work? and was it easy?
thanks
