BMW 3-Series (E90 E92) Forum
DP Fix for sale
04-23-2016, 03:43 PM | #1 |
Aw sh!t
112
Rep 994
$87 Shipped via Paypal. I made a DP fix for my e92. I know they go for $99.99 but I think $87 shipped via insured priority mail (USPS) for the same thing should be good. PM me if you are interested. This item fits the following BMWs: 2006–2010 E90/E91/E92/E93 335i 2011–2013 E92/E93 335is 2007–2010 E60/E61 535i 2007–2010 E82/E88 135i 2011 E82 1 Series M Coupe 2009–2016 E89 Z4 sDrive35i 2011–2016 E89 Z4 sDrive35is 1 week and no SES light. Any takers are welcomed. I can make more of them on demand. Thanks
Bigger is always better! M4
04-26-2016, 08:47 AM | #3 |
Aw sh!t
112
Rep 994
2 days and no SES light. So far the sitting I am using is good ~630 ohms. I will make few and take pics if anyone is interested
04-27-2016, 07:10 AM | #5 |
Aw sh!t
112
Rep 994
It should be good for the following:
This item fits the following BMWs: 2007-2010 E90/E91/E92/E93 BMW 335i 2011-2012 E92 BMW 335is 2008-2010 E82 BMW 135i
04-28-2016, 11:32 AM | #8 |
Rep 1,415
if it goes a week with no error ill take one. is there a way to check readiness? through inpa or something? thanks
2007 335XI SEDAN // JB4 G5 // BMS METH KIT // VRSF DOWNPIPES // AFE DCI // ER CP W/ TIAL BOV // MMP SILICONE INLETS // XHP STAGE 3 AT FLASH // TREBILA BEF // BMS OCC // VRSF EXHAUST // FUEL-IT STAGE 2 LPFP // VRSF FMIC // PRECISION RACEWORKS IGNITION SYSTEM // CATUNED COILOVERS // CIC AND COMBOX RETROFIT //
04-28-2016, 11:40 AM | #9 | |
Aw sh!t
112
Rep 994
335boston55.00 |
04-28-2016, 11:50 AM | #10 |
Rep 1,415
ya man find out. im sure if you can prove it works people will buy. i will
04-29-2016, 08:19 AM | #11 |
Aw sh!t
112
Rep 994
Day 5 and no SES light. At this point I will try to voltage drop numbers but I believe the setting and setup is sound. Any takers are welcomed. I have one for sale and I can make on demand.
Thanks
05-02-2016, 10:55 AM | #14 |
Aw sh!t
112
Rep 994
05-02-2016, 10:58 AM | #15 |
Rep 1,681
Do a search for BMS DP Fix installation. The .pdf is saved out there somewhere. It's the one I used to install mine even thought it was a different brand (wiring is the same in all).
But 1 week may not prove anything unless all monitors are ready. I drove around with mine for over a week and it never threw a light but didn't set readiness in all monitors either. Then it threw a code for an O2 sensor and I had to fix it and start over. The 2nd time it set readiness and I passed emissions. Any cheap $20 code scanner can let you know readiness, it's what I use. |
05-02-2016, 11:01 AM | #16 | |
Aw sh!t
112
Rep 994
05-02-2016, 11:05 AM | #17 | |
Rep 524
Drives: E82 135i
05-02-2016, 11:12 AM | #18 |
Rep 1,681
05-02-2016, 12:05 PM | #19 |
Aw sh!t
112
Rep 994
I will post a screen shot of my BT scanner results.
05-04-2016, 07:15 AM | #20 |
Aw sh!t
112
Rep 994
So far so good. Any takers? If it dont work I you have 30 days to return it. Lmk. I will post the BT scanner Results this weekend
05-05-2016, 07:45 AM | #21 |
Rep 9,209
05-05-2016, 08:17 AM | #22 |
Aw sh!t
112
Rep 994
This is wired just like the BMS one. There is no or off switch. You just need to set the POT until the SES light does not come on. I found out that around 630~650 ohms works best. I will send it set at ~650 ohms to make it easier.
