      02-27-2014, 03:41 AM   #1
jpalermo
Drives: 2012 x6
poor gas milage
recently changed from stock 20 inch to 19 inch snow set up i now have a drastic change in gas milage is that normal or is there something else going on
      02-27-2014, 08:25 AM   #2
HPIA4v2
Drives: F80, F86
When you say poor, what the before and after mileage?
You will loose a bit of mileage due to higher rolling resistance on snow tires (they are softer afterall).
But if you loose alot maybe your overall rolling diameter is off going from 20 to 19, I assume your tire sidewall ratio is off.
      02-27-2014, 09:50 AM   #3
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
Agreed - if the diameter is off, the speedometer will be off and that could cause the mileage difference (it wouldn't be real, only calculated). In addition, don't forget about the reformulated winter gas which also makes mileage take a dump too!
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      02-27-2014, 09:58 AM   #4
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
The diameter isn't off - they are the proper size. It's just the soft winter tire compound. A lot more rolling resistance than stock tires. They were mine, and my new winter set up in a stock size is getting me the same mileage.
