      02-20-2014, 07:11 AM   #1
HansW
HansW's Avatar
Drives: looking for an E46 M3
2012 BMW E92 M3  [0.00]
Brake Rotor Upgrades
Last year I had to change my rotors and looked all over for some drilled ones, which I thought would look great. Apparently they are not available, unless I sent out the new stock rotors out to be drilled after the fact, not interested. Although I don't need new ones yet, I am hopeful that by the time I do they will be available. Does anyone have drilled rotors on their X6M? Has anyone seen them online or anywhere? Any rumours about them being available soon? If anyone out there has drilled stock rotors, I would really love to see some pics posted of them to see if my theory is true that they will look totally sick in the huge size of the X6M behind a set of wheels.
      02-20-2014, 07:40 AM   #2
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
Check out Adams rotors. He won't do drilled because the support structure is too complex to drill them without hitting it and weakening the rotor, but he does do dimpled rotors, which gives you the same effect.
      02-20-2014, 08:19 AM   #3
SouthShoreM3
Passes everything but the gas station
Drives: 2010 E90 M3
Hans there isn't a lot out there for the X/M models. Adams for just straight rotor replacement may be out best option. Or swap everything like I am for the brembo BBK. Much bigger expense though.
