      02-17-2014, 01:11 PM   #1
X6 Eddy
I'm a gun guy.
X6 Eddy's Avatar
Drives: 2014 X6
Headlights turn off as soon as the car does..
Should I not have some courtesy lighting to walk to the door?
Eddy
      02-18-2014, 02:08 PM   #2
Mani59
BMW Miniature Collector!
Drives: E38 735i SE Individual
I am guessing it's the same principle as the E60 LCI so you can try this...
With the engine off and just before you take the keyfob out of the slot (or might be you have to take the fob out), you have to pull back on the full beam stalk, and then your welcome homes lights should light up for the desired number of seconds as set in the idrive.
Hope that helps!
Visit my (mainly) BMW gallery http://jetone.co.uk
      02-18-2014, 10:39 PM   #3
X6 Eddy
I'm a gun guy.
X6 Eddy's Avatar
Drives: 2014 X6
That worked, thanks!
      02-19-2014, 08:46 PM   #4
6lacksheep
6lacksheep's Avatar
Drives: 2016 BMW X6M
Hope that helps!
What do you mean pull back on the full beam stock?
Thanks
      02-20-2014, 08:07 PM   #5
X6 Eddy
I'm a gun guy.
X6 Eddy's Avatar
Drives: 2014 X6
That worked. (After the car is turned up.. bull the High beam lever).. lights come on for pre-determined time set in idrive.
      02-22-2014, 10:33 AM   #6
Mani59
Thanks
Pull back on the full beam stalk towards you for a second and then let go.
