      07-08-2016, 12:21 PM   #1
bmwstve
Drives: BMW X6, MHD Stage 2
Will they fit? 285/40r22 and 325/35r22 fit e71 x6
Guys, If you are running on 22" rims
Will the 285/40r22 (Front) and 325/35r22 (rear) tire setup fit E71 X6?
*same tire sizes used on the new Mercedes GLE coupe
cause the usual 295/30r22 front and 335/25r22 rear is a bit too thin and the rims can easily be damaged by potholes.
      09-01-2016, 12:54 PM   #2
rb404
Drives: 2016 BMW X6
Follow up
Did you ever find out if this size tire would fit? I have the same concerns.
      09-17-2016, 08:07 AM   #3
bmwstve
no, not yet cause no one was replying here, but most probably it wont cause if I remember correctly I've read a post before, max size for a 22 inch rim is 285/35r22 or 265/40r22 for the fronts. 285/40r22 might be too tall for X6.
      11-21-2017, 11:56 AM   #4
Topshelf22
Drives: Bmw x6
I cant find an answer anywhere.. i am running 35 series on fronts and 30 series on rear and i want to go bigger too
      11-22-2017, 02:33 AM   #5
peter2772000
Drives: 2012 X6 35i Sport
I'm almost 100% positive that the tire sizes mentioned will fit. "If" I recall correctly, it's part of the sport package. I can confirm this only when I'm back down in FL December 22nd, which is where our truck is.
EDIT: On Tire Rack, they list 275/40R20 and 315/40R20 as the tires on the Sport package, so I may be wrong.
The "M" has 285/35R21 & 325/40R21
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      11-22-2017, 03:25 AM   #6
bmwstve
M has 285/35/21 and 325/30/21
285/40r22 and 325/35r22 are tires used on Mercedes GLE Coupe
but they seem to be alot bigger compared to 325/30/21. approx. 2.3 inches taller
      11-24-2017, 03:20 AM   #7
peter2772000
Sorry, punched in the wrong number
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      02-13-2023, 06:25 PM   #8
ATX6M
Drives: BMW X6M
I can say that 285/40/22 on a 22" rim with 40mm offset will NOT fit-even with a 12.5mm spacer.
I am ordering 20mm spacers in the hope that they fit...if not, ill have a set of 285 and 325 up for sale soon.
Has anyone used a 20mm spacer to clear a 285/40/22?
Thanks in advance!
      09-22-2023, 08:32 AM   #9
B3VM3N
Drives: Bmw x6 i50 2013 E71
Thanks in advance!
Why wont they fit? Whats the issue?
      09-25-2023, 09:16 PM   #10
B3VM3N
Thanks in advance!
why?
