      12-04-2015, 10:13 AM   #1
SirMedo
SirMedo's Avatar
Drives: BMW X6 5.0
Maybe tune issues..... Ideas??
Hey guys,
I have a 09 BMW X6 5.0…. Love the car so I got a ESS Tune for it. When I run the tune I get the following codes 2B16, 2B19, 2B22 and 30FF. When in 5ht gear on the freeway with the throttle half ways down the car starts boosting and then it acts like there is an interruption somewhere then it goes into limp mode.
When I have it on stock the cars runs great with no issues. I had the dealer check the car and was unable to find any issues with it. I have been working with ESS guys to help me figure out the issue. ESS rocks…. Those guys are so helpful I go to say.
If you guys have any ideas about the codes please let me know I would appreciate it. If I knew what was going out or bad, I would replace it.
Thanks guys
      12-04-2015, 10:41 PM   #2
peter91118
peter91118's Avatar
29
Drives: '01 325xit, '09 335i
This is a good resource
http://www.bmwforums.info/bmw-electr...es-list-3.html
I would check for a boost leak somewhere
      12-07-2015, 07:01 PM   #3
SteveMD
SteveMD's Avatar
196
Drives: 2016 F10 535i MSport
I would suggest it's either an injector or a coil pack. You should also check your plugs. Those three items are the first to reveal themselves when you up the boost on an N63.
Google those codes. I think 30FF is a boost leak which could make itself noticeable when you run few a more psi.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      12-09-2015, 03:39 PM   #4
SirMedo
SirMedo's Avatar
Drives: BMW X6 5.0
Thank you guys for the response…. I have had the injectors replaces about a year ago. I am thinking about replacing all the coils and see if that helps the issue. Thanks to Peter91118 the codes are as follow.
2B16 Throttle valve actuator governor monitoring, bank 2
2B19 lonic current signal amplification, bank 1
2B22 Throttle valve actuator pre-drive check, bank 2
30FF Low Boost
I am not sure how to check for leaks but I guess I’ll google around a bit. ESS Tech has been helping with getting a different map as well to try it out. Awesome support from them for now.
At this point the car has a hard time starting as well. It cranks for about 5 seconds here and there and it barely starts but still no codes for anything.
Thank you guys for your help.
      01-18-2016, 07:18 PM   #5
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Keep us posted.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      02-23-2017, 04:54 AM   #6
m5james
m5james's Avatar
Any updates on this? Stock flash, no issues. Stage 2 flash, no issues. JB4 map 6 and I get 2B16, 2B17 and 2B22.
      02-23-2017, 09:40 AM   #7
JoeyBimX5din
Drives: 2011 BMX X5 Xdrive50i
If I had to guess with those codes you have there, the ESS tuning is incorrect for the throttle control. Something in the code has to be setting those codes, as in, the truck is looking for a certain amount of throttle actuation, it isn't obtaining it, then it throws the boost code. Sounds like a definite ESS issue. Have you told them the codes your getting? It may be something wrong with your particular tune if you are the only one having the issue.
Keep in mind I am a mechanic, but not a professional BMW mechanic, some of the stuff I am saying is probably wrong, but just an idea.
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD
1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about
1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter
      03-23-2017, 08:10 PM   #8
m5james
m5james's Avatar
OP needs to flash back to stock and see if the same problem exists and/or search for the Reduced power warning thread on here where it can be anything from a boost sensor (a code I received) but was ultimately fixed by replacing the vacuum lines. I myself resolved my post tune & JB4 high boost/misfire issues by going to colder plugs with tighter gaps...it's a freaking monster at 20psi!!
      03-24-2017, 09:42 AM   #9
JoeyBimX5din
oh those NGK's listed in your sig are a colder heat range plug?
godmans16.50
      03-27-2017, 11:23 PM   #10
m5james
m5james's Avatar
Yes, they're a two step colder plug.
      03-28-2017, 11:39 AM   #11
JoeyBimX5din
Did you switch to them once you got tuned?
