07-29-2013, 08:04 AM | #1 |
Rep 126
Brightest Angel Eyes
looking at getting some new angel eyes, and i was wondering who has the best and brightest angel eyes???? help please.....
07-29-2013, 10:22 PM | #3 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
LUX H8 v3
07-31-2013, 09:45 AM | #4 |
Rep 11,139
If you have angel eyes that are currently powered by a halogen bulb, there is only so much you can do to make them "brighter". Most of the time, the inside corona will light up bright but the outside one will look completely washed out.
If you really want to step it up, you will need to retrofit the LCI angel eyes as they are powered by a superbright LED on the BOTTOM of each ring. The halogen (pre LCI) has one bulb for both coronas. Do some research on the way fiber optics work and you'll see that often times adding brighter bulbs does not result in brighter angel eyes. Most of these aftermarket LED or whatever kits then ultimately are a waste of money. What the pre-LCI design looks like. And the LCI design. Completely different and no way to replicate. |
07-31-2013, 11:19 AM | #5 |
469
Rep 4,938
We now offer the LUX H8 V4 angel eyes. They are about 20% brighter then the V3's and by far the brightest on the market.
07-31-2013, 12:38 PM | #6 |
Rep 304
08-01-2013, 11:30 AM | #7 |
469
Rep 4,938
http://www.e90post.com/forums/showthread.php?p=13954109
Price for these is $249 + $10 shipping, only $4 more then the LUX H8 V3's
08-01-2013, 12:17 PM | #8 | |
Rep 333
If you look at the lights from a slight angle, you will see the outer rings becoming really dim. I am currently using LUX. It is great. Probably the best LED bulb you can find in the market. If you like it, definitely go for it. But keep in mind of what P1et said above. If you are a perfectionist who seeks what the LCI LEDs look like, this will not be the way to go. After my warranty expires, I will be opening my housing and replace the entire ring with LEDs. I found someone local who can do this for $200-$300 only. That's the price of a LUX package. It is something similar to the OSS in this post, but with a more uniform light: http://www.luxury4play.com/bmw/10577...kout-pics.html http://ossdesigns.net/ Or if you have the money, get the OEM LCI headlight unit and retrofit it. Last edited by zerrantoss; 08-01-2013 at 12:26 PM.. |
08-01-2013, 10:54 PM | #9 |
Rep 9
Drives: 2011 X6 50i
I took the cheap way out and went to ebay and found 20w cree bulbs for $80/ pair. Installation was a PITA. It seems like they used the person wiith the smallest hands to engineer the bulb compartment. As some previous posts mentioned, replacing the bulbs may not get you brighter lights, but you can improve from the yellow halogen and get whiter lights. No complaints from me.
08-02-2013, 12:02 AM | #10 | |
Rep 1,423
Drives: '07 N54 e90, '10 N54 e93, TBSS
Got another set for the x5 sitting here ready to go in Saturday! You could spend 3-4x the price but you aren't getting 3x the brightness like 2012+ models. Taking the extra money and color matching the moldings
E90 - H&R Touring - M3 Front Arms - Work Genosis GS-1 19x9+30 x10+26 225f 265r stretch - AA FMIC - AR DP - Cobb E30 Map +160rwhp/+200rwtq
E93 - Style 95 - RB Turbo - AR DP - Evolution RW FMIC - PTF E50 +242rwhp/+234rwtq |
08-03-2013, 09:46 AM | #11 |
Rep 1,423
Installed mine last night!
Pro tip remove the wiring harness before twisting the bulb out! Figured this out on the second side much easier bc the factory wiring isn't long enough to get a good grab and you'll end up scratching the stock halogen. Tip 2- look thru the headlight to line up the 3 points on the bulb, twist and move up and down to get the gasket squished. Can't be beat! Now find a body shop for that ugly Unpainted trim! |
08-06-2013, 08:29 AM | #13 |
Rep 1,423
That tool wouldn't help twist the bulb in and out of the housing.
That would only help remove the hardness which a flat head screw driver does well. |
08-08-2013, 11:14 AM | #14 |
Rep 11,139
Twisting the bulb is not the hard part (or at least not for me). The hard part would be to unclip the harness and fish it back to the bulb once it's time to reconnect the cable. That is what the tool was handy for. You scrape your hands up a bit taking out and putting the bulb back in, but that harness connection would have been impossible for me.
08-14-2013, 08:51 AM | #15 | |
Rep 265
PlaZma Series Daytime Running Light Replacement LED Bulb (H8) by Lumen®, 1 Bulb. 5-LEDs bulb, 420 lumen of light with white color, 360 degree light output. Offers twice the brilliance of standard LEDs using the same power, and features a lifespan 25 times longer than incandescents at a lower operating temperature. Designed to plug into OEM connector without modification. Available in multiple colors. |
08-20-2013, 02:41 PM | #16 | |
469
Rep 4,938
