01-05-2024, 09:10 AM | #2 |
Rep 140
I had a broken Xenon ballast a view weeks a go. Replacing is a DIY, but still some nasy work because the inner front wheel housing has to come of.
Taking out The Wheel arch was a PITA, but putting it back was a double PITA. Remove the torx screws (4) from the headlight and pull it a bit back, that will give u just enouf space to remove and replace the ballast. The ballast is mounted at the under side of the headlight, with 3 torx screws. |
tiredrelief0.00 |
01-07-2024, 10:40 AM | #4 |
Rep 395
