      06-30-2012, 11:50 AM   #1
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
OEM 20's and Alignment
Im looking for some input from the forum.
My two front tires are showing wear on the outside edges. They have just about 17k miles on them. They are the Bridgestone Runflat 20's.After noticing the wear I thought my alignment was off but then noticed other X5's with simil'ar wear.
My dealer said my tires "are shot and need new tires and alignment." I dont think they are totally gone yet, but understand the wear is significant.
I got the alignment done at the dealer and suggested they adjust the toe as close to 0 as possible and add more negative camber, which I have heard is really hard if not impossible to adjust. This all in an effort to counter the outside wear.
After the alignment, the car hangs to the right, which it did not before alignment. The steering wheel is not centered either.
I plan to go back soon and get it re aligned.
Here are pictures of current tire wear.
Any thoughts?
      06-30-2012, 10:06 PM   #2
watrob
watrob's Avatar
Australia
140
Drives: MY2022 X5 M-Sport 45e White
You need a front wheel alignment alright, I never buy a new car without recieving the wheel alignment printout.
I make the dealer do a wheel alignment, they charge you a delivery fee so make them earn it. The statement that its done at the factory might all well be true but its what happens to the vehicle by the time you get thats the problem.
And you should keep an eye out on your tyres, that sort of wear would be noticeable in the first 500 miles and you could have taken it back to the dealer and asked for a wheel alignment. If there is no visable marks or scratches on your wheels the dealer would do it under warranty.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked.
      07-01-2012, 08:54 AM   #3
delio13
Drives: 2011 X5 35d
Yeah I have the same problem on my 2011 x5 35d at 5000 km noticed all tires have unusual wear took it to the dealer and said that they are aligned that way for handling but I don't understand why. The wheel base of this suv is so wide that we don't have to worry about tipping over and the suspension is so stiff why put a positive camber to enhance the performance on cornering. I don't want to have to replace tires e every 12000 km that gets expensive especially on 20 inch tires
      07-01-2012, 09:54 AM   #4
avalon652
avalon652's Avatar
Drives: Soon to be 2024 X7 M60i
Yeah I have the same tires on my 2011 X5 50 and the EXAXT Same
Problem; rear tires look great, outside edges of the fronts are bald...it's my wife's car and I rarely drove it so I didn't notice till it was too late. Might hold out a little longer but new tires and a better alignment are in my near future.
      07-01-2012, 10:04 PM   #5
watrob
watrob's Avatar
Australia
140
If you get a wheel alignment now you will still get plenty miles out of those tyres.
      07-02-2012, 02:38 PM   #6
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
thanks for your guys' input. i agree with everyone. especially with watrob, i definitely will request alignments upon purchase/lease of new cars
i got an alignment done a few days ago and it drives alright, hangs a little to the right and the steering wheel isnt centered exactly, but its bearable.
i told the dealer about this but they say its because of my existing tire wear, lol. so we are going in circles. the car drove strait before all of this. ill give it another week and see what happens.
      07-02-2012, 05:56 PM   #7
watrob
watrob's Avatar
Australia
140
I have noticed on your second tyre photo (lefthand front wheel) every third rubber lug has a raised edge, you can tell by the dirt on those raised edges. This is a sign also of under inflation (scolloping) due to heat.
      07-03-2012, 03:09 PM   #8
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
ah yes good catch I have made sure to adjust the tire pressure.
      08-21-2012, 02:12 PM   #9
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
close to 20k miles and wear has gotten worse even with new alignment.
time for new fronts.
      08-21-2012, 05:54 PM   #10
Mitch P.
Drives: '17x5M
Annoying as I have the EXACT same symptoms yet I am only at 10kmi - outside Dunlops are bald. I contemplated the Conti's, but do not want to lose runflat/get a spare due to 3rd row seating option.
My next set will be with a fresh alignment to reduce toe to as near as 0 as possible. I'm annoyed because I thought my last 4.8is E53 was bad at tire wear around 15kmi - now I'm only at 10kmi and bald tires - grrrrrr.
Mitchell Phillipi, CCA#189329
'01540ias, '17x5M
past:'96Dinan3, '11M3 ZCP, '11X5d, '15X5 5.0, '07AMdB9
      08-21-2012, 06:38 PM   #11
NRG
NRG's Avatar
Russian Federation
36
Drives: 2012 X5 35d
Same with mine, 20" Dunlops 17k miles the rears are perfect still 50% good. The left front is bald outside, right front is ok, both have less then 30% left in them. Had to put a new rubber set all 4, did an alignment before putting new ones on, dealer said it was bad. Car drove straight, with a slight hint to the left barely noticeable.
Retired: 2005 N52 E90 330i Sport 6AT
Retired: 2007 N54 E92 335i Sport 6AT
Current: 2012 M57 E70 X5 xDrive35D
      10-11-2012, 08:51 PM   #12
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
Just picked up some continental DSW's for the fronts. havent put them on yet. any suggestions for Chicago area installation?
      10-11-2012, 10:27 PM   #13
watrob
watrob's Avatar
Australia
140
All X5's pull left, the lefthand front wheel is set back 5mm futher than the righthand side wheel, this becuase of the camber of the roads and the X5 is really designed as a lefthand drive vehicle to suit both Europe & the US.
So you can see what happens when you make it a righthand drive and drive it on the opposite side of the road that has lefthand camber. To overcome the pulling left you need a castor kit to pull the lefthand wheel forward and pull the righthand wheel back 5mm.
      10-11-2012, 10:30 PM   #14
watrob
watrob's Avatar
Australia
140
Any thoughts?
Bottom photo shows sign of scolloping, tyre has been driven on with to low a tyre pressure.
      10-12-2012, 08:34 AM   #15
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
I got a 2012 E70 35i Sport, same issue at 15k miles. I hit a pot hole 5k miles ago, so I thought that was the cause. Now reading this thread, I realize the X5 alignment is setup to pull to the left causing the left front to wear first, then right front, then rears.
I hate my noisy and heavy Dunlop RFT. I just ordered a set of Continental ExtremeContact DWS (non-RFT) for all 4 corners. I hear amazing reviews on these shoes. They should be quiet and drive better. For the price of 2 front Dunlop RFT, you can get a set of Contis.
      10-12-2012, 02:18 PM   #16
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
I just put Continental ExtremeContact DWS's on my front and i actually do notice a smoother ride. Those run flats were rough. cant comment on noise reduction but i think once i get those tires on the rears too, itll be noticeable.
Also I realized that with the lack of camber on the X5's, maybe the weight of the car on turns adds to the excessive wear on the outer edges of the tires.
      10-12-2012, 03:46 PM   #17
Mitch P.
Drives: '17x5M
I just got a set of takeoff Bridgestone's for $800 and the rig is in for an alignment, mount and balance. My stock dunlops only lasted to 12kmi and I'm extremely irritated. I'll report back here with the alignment specs before/after and hopefully these Bridgestone's will last a bit longer
I'd have gone with the Conti's, but really like the idea of having the runflats - especially due to our third row option and travel habits. I may be in the minority, but I actually like the slightly stiffer ride of the runflats vs the softer sidewall Conti's. I ran those on my previous E53 4.8is and did NOT notice any improvement with tire wear - regardless of the fact that the treadwear is sky high in comparison to other tires. On that rig I ran the Diamari's, Latitudes, and the Conti's and all of them wore down at similar mileage. Remember, each manufacturer rates their treadwear from what I recall so I take treadwear with a grain of salt.
'01540ias, '17x5M
      10-12-2012, 09:35 PM   #18
335i_4D
Now in the dark side !
335i_4D's Avatar
Drives: 2011 911S 997.2 Cab
Same here.
Also the added security feeling when my wife and kids takes the X5 for a ride in town, going accross a very long bridge without any shoulders...
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey)
Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed)
2010 X5 35d Black fully loaded (Sold)
2007 335i sedan Antracite (Sold and missed !)
      10-13-2012, 10:07 AM   #19
3s-a-charm
3s-a-charm's Avatar
Drives: 2017 Tesla Model X
2007 BMW X5  [0.00]
Me too! I always thought this was due to all the aggressive cornering in such a heavy vehicle.
Funny, I came from an E92 M3 to this and still can't believe how this truck takes corners!
17 Tesla Model X 90D (I've been converted!)
PAST: 14 Tesla Model S P85D, 16 X1, 13 X5 M-sport, 04 M3 Cab, 08 E92 M3, 08 535xiT, 07 X5 4.8i, 06 E90 325i, 87 E30 325i, 85 E30 318i
      10-13-2012, 11:48 AM   #20
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
Originally Posted by '10-X5-35d View Post
Same here.
i think its a great idea especially with the third row option and knowing others driving the car will be safer when it comes to potential flats. if i had a family or kids driving it i would definitely do the same.
      10-13-2012, 01:43 PM   #21
Mitch P.
Drives: '17x5M
I can't believe I even achieved 12,888mi on the Dunlops with these alignment settings - ugh
Before/After
Front left
Camber -0.3/-0.3
Toe 0.17/0.06
Front right
Camber -0.1/-0.1
Toe 0.11/0.06
Rear Left
Toe -0.05/0.07
Rear Right
Toe -0.1/0.06
Before/After
Front total toe 0.27/0.12
Rear total toe -0.15/0.14
Crossing fingers that I can get >15kmi after the alignment
'01540ias, '17x5M
      11-15-2012, 10:06 AM   #22
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
after a couple thousand miles... love the Conti DSWs. Much more comfortable ride.
