      03-02-2014, 11:05 AM   #1
och
Drives: .
2012 X5 xDrive50i  [0.00]
2018 BMW M2  [0.00]
2017 X6M  [0.00]
2013 Suzuki Bouleva ...  [0.00]
Increased battery drain and remote access stopped working?
I got a warning message on the screen yesterday about increased battery drain, and the car no longer opens closes when I pull/touch the handle. What can be the cause of that?
      03-02-2014, 03:26 PM   #2
ADGrant
Drives: 2011 X5 5.0
You may need a new battery.
      03-02-2014, 03:50 PM   #3
Sylvan Lake V35
Vanilla Gorrilla
Sylvan Lake V35's Avatar
Drives: X5M & X5 35d
Or get a trickle charger and charge your current battery, I trickle charge mine every two weeks or so.
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
      03-02-2014, 04:01 PM   #4
mvigod
mvigod's Avatar
Drives: 2021 X5M
Battery low. take a long drive or put on charger. My '13 M5 just had this few days ago. Put it overnight on Ctek 7002 charger on normal mode and 24 hours later fully charged. AGM batteries have slower discharge so a good battery should hold for quite awhile after being topped off.
If you trickle charge you might want to make sure you use the AGM setting on your charger so you don't toast it (if your battery is AGM type).
My M5 has basically sat for almost 3 months now with the dreadful northeast weather (snow, salt, sand). I usually start it and let it run for 5 or 10 minutes and roll the tires so no flats every 3 to 4 weeks but that wasn't enough and needed a charge.
If you still get it after a charge your battery likely needs replacement
      03-03-2014, 02:29 PM   #5
ChiTownM
ChiTownM's Avatar
Drives: M and i BMWs
Had the same issue off and on.....dealer checked and battery charged to 35 percent overnight. New battery fixed everything. Btw, the battery was so weak that the comfort access locked the doors even though the key was inside the truck, which locked us out during a snow storm......lesson learned on things not being fool proof.
      03-03-2014, 06:53 PM   #6
ingenieur
ingenieur's Avatar
24
Drives: 2011 335d MSport
Does it not work from any door or just the driver's?
      03-04-2014, 08:42 AM   #7
SouthShoreM3
Passes everything but the gas station
Drives: 2010 E90 M3
I had this same issue OP. we replaced the battery twice. Ended up being one of the door handles.
      03-04-2014, 04:03 PM   #8
akashyap
Drives: F80 M3 & E46 M3
I had the same issue. Battery was dead, replaced and no problems since.
E46 M3
CDV Delete, Auto Solutions 30%, SGT Coilovers, TopSpeed Exhaust
F80 M3
Stock
      03-05-2014, 10:39 PM   #9
och
Drives: .
2018 BMW M2  [0.00]
2017 X6M  [0.00]
The issue went away by itself. I think it might have been because the car sat for like a week or two due to crap weather here in NYC.
