      03-06-2014, 11:45 AM   #1
mrpcar
Drives: 2012 X5M
Cracked vacuum line on X5M
Anyone had this issue yet?
A crack vacuum line above the turbo chargers. Engine malfunction message, car stalls, had to get it flat-bedded to the dealer.
Seems kind of stupid for BMW to put a brittle vacuum line right above the turbo chargers.
My X5M is only 2 years old with 34,000 miles.
Unrelated, but I am curious to know have anyone removed the engine top cover to help dissipate the heat generated by exhaust from the inner V area?
      03-06-2014, 11:56 AM   #2
mrmomo313
mrmomo313's Avatar
Drives: M6 Gran Coupe
Had mine replaced around 28.500 miles... according to my SA it is normal for that part to fail around 30k (don't know why the guys at M couldnt catch that in long term testing). My car didn't throw any faults but I noticed it wasn't pulling as hard. After it got replaced along with all my spark plugs at the 30k service it was pulling harder than ever. Guess I'll be replacing it in another ~30k miles if I still have my truck then.
2012 X5M Monte Carlo Blue/Black-SOLD
Velos Stage 2/Velos Catless downpipes/Dinan exhaust/Dinan Suspension
2018 M6 Gran Coupe Competition- Singapore Grey/Aragon Brown
DME Stage 3
      03-06-2014, 11:57 AM   #3
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Going to have to take a look at mine now. Thanks for the pics.
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      03-06-2014, 12:00 PM   #4
mrpcar
Drives: 2012 X5M
Car is still at the dealer, but once I get it back I will wrap some sort of heat insulation material around the two tubes, just so I don't have to deal with this again. And keep a roll of duct tape in my trunk so that I don't get stranded when this happens again. Luckily this happen in my driveway while I was headed to work.
      03-06-2014, 12:12 PM   #5
X5M_DA
Drives: X5M
Mine replaced at 57k the code 0011920200
      03-06-2014, 01:27 PM   #6
JVX6M
JVX6M's Avatar
Drives: 2023 BMW M3 Comp
Sorry I'm not a mechanic but is it the ribbed one or the other? Also is that the replacement or the cracked one?
      03-06-2014, 01:28 PM   #7
mrpcar
Drives: 2012 X5M
It is the ribbed one, if you look at the middle of the picture you can see the crack and the oil around the hose.
      03-06-2014, 01:55 PM   #8
JVX6M
JVX6M's Avatar
Got it!
Thanks
      03-06-2014, 10:44 PM   #9
nabizzy
Drives: 2018 X5M LBB
just had this done last week
      03-07-2014, 04:44 PM   #10
zoex5m
Drives: x5m
Mine was replaced at 44k.
      10-26-2014, 11:52 AM   #11
GGX5M
Drives: 2010 BMW X5M
this just went bad for me last night. still driveable. 71k
      10-26-2014, 12:01 PM   #12
shark715
Drives: '11 X5 50i, '16 M235xi vert
Originally Posted by mrmomo313 View Post
don't know why the guys at M couldn't catch that in long term testing
No doubt they do long term testing, but the one thing it's tough to test accurately is what happens to different materials with just the passage of time (never mind the severe heat that this is exposed to). That being said, if they had no choice but to locate the vacuum line here, they could have taken steps to do a better job of protecting it.
      10-26-2014, 04:41 PM   #13
JVX6M
JVX6M's Avatar
Just had mine done at 38k. Got the reduced driving CEL one time during a rough idle. The car continue to idle rough and off for a couple weeks but with no CEL. When I went in for servicing the issue was supposedly a cracked vacuum line.
      10-27-2014, 12:02 AM   #14
WallyM5
WallyM5's Avatar
42
Drives: X5M, R63 AMG, F-450
Somebody please confirm this part number if possible.
11157595188
http://www.ecstuning.com/Search/11157595188/ES2079658/
Thank you,
"An on ramp is a terrible thing to waste"
EuroCharged Tune--QTP 3" Cutouts--V1 Hardwire--K&N Carbon Delete
OEM Muffler Mod--(Best Mod Ever) 15mm Front Spacer--20MM Rear Spacer
      10-27-2014, 09:06 AM   #15
madmille28
Drives: na
We would it be a better option if we replaced all the turbo vacum hoses with silicone hoses? I believe silicone hoses can withstand higher engine temps.
Thoughts?
      10-27-2014, 10:14 AM   #16
mitch808
Drives: 2012 X5 35i
Thoughts?
At the risk of using a non-BMW part, and completely voiding your entire engine warranty? No.
Add to that, proper maintenance of checking for aging rubber is simple, and replacing on an ad-hoc basis, even simpler; than replacing all rubber bits...
      10-27-2014, 08:10 PM   #17
godmans
Drives: 135i / 335i / X6M
11157595188
Thank you,
I am going to order this and will report back once i get a chance to get it and compare; but from what i can research thus far, this seems to be the right part for the S63 engine
      10-28-2014, 12:20 PM   #18
SteveMD
SteveMD's Avatar
193
Drives: 2016 F10 535i MSport
Based on the heat I have experienced coming off those turbos, I'd be worried about the paint on my hood.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
WI_Rob93.50
      11-01-2014, 08:41 PM   #19
///Mpower///
Sergeant
///Mpower///'s Avatar
Drives: Spiritedly
My mech said the same thing re: the heat...it would likely bubble the paint on the hood.
_______________
///M
'16 535i Xdrive Msport
'13 M5 - Singapore Gray, Black Ext. Napa, Dinan FF Exhaust, much more to follow.
'12 X5 M - Carbon blk, Cinnamon interior <retired>
      11-02-2014, 08:59 AM   #20
vinster88
vinster88's Avatar
Drives: '12X5M
I pulled my engine cover off at least six months ago, when I read about this.
Its been noted on work orders when i've been in for service, but no i'll effects.
      11-02-2014, 06:51 PM   #21
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
Just had my car in the dealership for it's first service, 1 year 18,700kms. I noticed the crank case breathers had some oil residue on different parts of the hoses. The dealer replaced all the PCV hoses and part number are as follows.
11-15-7-589-989 vent pipe
11-15-7-589-992 vent pipe
11-15-7-595-188 connecting line
13-71-7-848-152 filtered air duct
Hope this helps for those of you searching for parts.
Also I wonder how hard it would be to make a oil catch can for our cars, it would completely eliminate this issue
      12-23-2014, 10:17 AM   #22
vinster88
vinster88's Avatar
Drives: '12X5M
So, I began to smell a bit of oil burning...
after a short search, I located the source. The connecting tube was leaving residue on the metal bracket that is over the Turbos.
It would seem that removing the engine cover does not help in anyway to eliminate the hose melting problem.
The part number: 11157595188
Is correct, the cost is 28.00 at Getbmwparts. The same part just cost me 44.95 at the local BMW parts Dept.
I would suggest either calling it a maintenance part and replacing in say every 25K. Or have one on hand, so that you don't have to pay inflated prices to keep the tow truck out of your life.
