03-13-2012, 07:16 AM | #1 |
Rep 8
Hi End Individual Optimal EQ settings
Hi there,
I am about to switch from E92 to new X6 with High End Individual Audio system. There's a great post on e90/e92 Logic 7 EQ settings (http://www.e90post.com/forums/showthread.php?t=161120), but I couldn't find anything similar for X6 and, in particular, High End System. Can anyone help, pls? |
03-14-2012, 06:40 AM | #2 | |
Lord Vader
Rep 162
Would also like some advise on this.
My ugly illusions are such a beauty!
08-21-2012, 10:42 AM | #4 |
Rep 1,828
Drives: 2016 Tesla Model X P90DL
I have an upgraded hi-fi sound, but i would use it on Logic 7 as well
Fairly simple - i raise lowest frequency by a couple of bars and highest by a few bars Next-to-highest just get 1 or 2 bars bump up It's pretty much flat with some extra bass and highs If your source is very good (i get lossless if i can) then you should not need much of EQ manipulation IMO |
08-23-2012, 04:40 AM | #5 | |
Rep 2,725
CD is good but much weaker than radio station, files from itunes via iphone are just ok (with using an official plug-in adapter). I now have a high-end individual system (I supposse it is the equivalent of Premium Sound option in USA), it is better then the logic 7 I had (which was also very good)...To sum it up, I would like to know how to get the best out of the system I have now since I am not an expert in the field, but like a good sound. |
08-23-2012, 10:11 AM | #7 | |
Rep 1,828
I just have 10kHz a bit lower than yours and 5kHz in just one notch above flat I also set bass close to max and trebble to max setting and adjust it a bit depending on the source. Sat sound is not as bright as CD/MP3, it's missing very highs/lows I also programmed my 5th button to jump to tone setting directly |
08-25-2012, 12:01 AM | #8 |
macd1995
17
Rep 284
Drives: 2008 328CI, 2013 X6 5.0
The Logic 7 cannot touch the system in the X6. The warp sounds (particularly the bass) with the Logic 7 is not apparent on the X6. I plan on asking a friend with a PHD studying sound waves to give me his suggestion. If it is pleasing to my ear, I'll keep it and share.
08-29-2012, 03:28 AM | #9 | |
Rep 8
08-30-2012, 10:12 AM | #10 |
macd1995
17
Rep 284
Sorry.. I always do this to him.. its a Masters - not a PHD... I hope you will be not be disappointed.
09-03-2012, 10:12 AM | #11 |
Rep 8
Tags |
high end individual eq settings |
