      04-06-2017, 08:12 PM   #1
Limit
Drives: 2011 BMW X6 35i
Fan blowing full blast for a split second
Hope can get some advice.
I have recently noticed that the vent blowing full blast for a split second and then back to normal. Happened a couple of times already while driving on the highway.
FYI, electric coolant pump was recently replaced, but not the thermostat, not sure if it is related
Any help is greatly appreciated.
      04-06-2017, 10:42 PM   #2
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
I get it randomly as well, no clue.
      04-08-2017, 02:42 PM   #3
-c-
-c-'s Avatar
Drives: bmw
I've been told it's the beginning of the end for your water pump.
      04-14-2017, 09:12 PM   #4
m5james
m5james's Avatar
Water pump? We're talking about the interior fan for the climate control, not the engine fan.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      04-15-2017, 11:02 AM   #5
-c-
-c-'s Avatar
Drives: bmw
Lol. My bad, reading these on my phone sometimes don't catch the small print
      05-07-2017, 02:03 AM   #6
dreamalaska
Drives: 2013 X6 3.5i
Does this do this randomly while driving? Mine will blast the front defrost for a few seconds on startup if it's rainy and cool outside, but otherwise acts normal...
      05-13-2017, 12:08 PM   #7
BMW-SRT
Drives: C63sAMG, GLC63sAMG, x5m, 335i
This happend to me for the 1st time a couple days ago when i switched the vent to blow from the top and bottom, when i switched it back to only blow from dash vents it stopped/was back to normal, so weird.
      05-18-2017, 10:04 PM   #8
n_sievers
Drives: 2012 X6M Monte Carlo Blue
2012 X6M  [0.00]
This regularly occurs for me, especially if the sunroom is open. When I had in for service a brought it up and was advised that is was "normal vehicle function". Not sure I believe it but they would not discuss any further.
      05-19-2017, 09:36 AM   #9
Limit
I have started noticing a trend that the interior vent blowing full blast for a split second when:
1. Quickly accelerate to highway speed
2. Outside temperature around 10 celsius when inside temperature is set to 16 celsius
3. Fan setting is set to lowest
Could this be the symptoms of a failing final stage resistor (FSR)?
