      10-02-2023, 01:33 PM   #1
former 240 s14
Drives: 2011 Comp E92 & 2008 E90 S65
Exclamation Help/Clarification Needed M57 Injector Code 4592
Hello Community,
I have an E70 X5 with the M57 that recently had an injector (Cylinder 4) go out. The vehicle had a carbon clean and hit a pothole about 10k miles ago and was done before the injector failed. I ordered a new injector, installed,, coded and reset injector adaptations using my Autel MaxiApp200. Now the X5 runs great at highway speeds but struggles to find it's idle and is a bit stumbly at take-off. I randomly get two codes for cylinder 4:
4592 Smooth running controller, cylinder 4
P0304 Cylinder 4 misfire detected
I have been researching on the forums and it sounds like there was a software update and adaptation reset for the inremental wheel sensor that fixed alot of these issues but I am not sure if my issue is tied to this.
For anyone who fixed their X5 using this method I have a question, did you have multiple cylinder codes or just a single/combo of injectors?
Just trying to find the root cause of the issue and fix this for good.
Thanks in advance!
Rubin
