Dear Members,
We have 6 weeks to go for the Summer and we are starting our annual end of Summer Stoptech blow out Sale on ALL Stoptech Big Brake Kits and Offerings!! This applies to everything Stoptech!!! Do not miss out.
Please include all the following in your request
Year of Vehicle -
Color Caliper -
Slotted or Drilled -
Piston Selection (4 pistons or 6 pistons, only 4 pistons for the rear)
Front only or Full Kit -
note - Please keep in mind only Red, Black, and Trophy finishes are recommended for the track.
StopTech® Big Brake Kits exceed stock performance in two key areas: First, larger rotors increase heat capacity, allowing a driver to brake harder stop-after-stop with reduced chance of fade. Second, stiffer calipers and stainless steel lines reduce system compliance, providing consistent pedal feel and confidence-inspiring responsiveness.
The key, however, is to increase heat capacity and reduce compliance without upsetting a vehicle's stock front-to-rear brake torque ratio. That is why StopTech® developed the Balanced Brake Upgrade® design philosophy, which precisely apportions front and rear braking resources while factoring in vehicle weight transfer under braking.
In contrast, a brake upgrade that adds too much front torque (as many do), will reduce your car's ability to maximize the traction available from all four tires, robbing you of performance. In addition, a system that uses too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, limiting a driver's control of brake input.
StopTech® Big Brake Kits offer superior street performance.
They feature fully forged calipers with patented stiffening bridges, patented 2-piece AeroRotors® for optimized cooling, braided stainless steel brake lines, performance brake pads, mounting brackets and all necessary hardware to complete the installation. StopTech® Big Brake Kits were the first Balanced Brake Upgrades® on the market, offering optimized brake bias to utilize all the traction available from all four tires.
Balanced Brake Upgrades® with optimum brake bias offer the shortest stopping distance with the best pedal feel. Patented AeroRotors® offer the best airflow available for better cooling, less fade and longer rotor and pad life. StopTech® provides the stiffest fully-forged aftermarket calipers with patented, removable bridges that provide better clamping under hard braking and less pad taper. StopTech® Big Brake Kit components are made in the USA in a 70,000 square foot California manufacturing, engineering, and R&D center Trophy Big Brake Kit Quote: For ultimate track racing performance StopTech offers Trophy Race Big Brake Kits, with naturally anodized lightweight components designed to survive the rigors of racing. Trophy Kits feature fully forged, lightweight STR calipers, 2-piece AeroRotors®, braided stainless steel brake lines, mounting brackets and hardware. The MAX Float hardware allows for the greatest amount of float between the hat and rotor. These Trophy Race Kits are used on many of the top competitors in the SCCA Pro Pirelli World Challenge Championship as well as in Grand-Am and other race series. Ultimate street performance is obtained with a StopTech® Trophy Sport Big Brake Kit. The Trophy Sport Big Brake Kits are designed for street driven production vehicles and use the same STR calipers, AeroRotors® and AeroHats® as the Trophy Race Big Brake Kits, but add silicone dust boots to extend service intervals and anti-rattle rotor mounting hardware for quieter street operation. Trophy Sport Kits also include StopTech® Street Performance brake pads for high performance street and occasional track use. They are the ultimate street braking system.
