09-15-2010, 10:23 AM | #1 |
2nd to None!
42
Rep 296
Drives: M8 GC, M5 30Jahre, X6 50i
BMW X6 Carbon Fiber Update
Hi guys would like to share my recent modification to my X6. Just collected back from Robson Design in Singapore. Fitted it back in to my car look pretty good to me except the rear diffuser. It look too square IMO. May need to redo the whole thing, the four fins look great just that it is not router around on the edge and it look too square. Still waiting for the side skirt and side step to be carbon fiber laminated. So what do you guys think on those rear diffuser fins, too sharp, too big? It don't look really right to me.
Just got a call from Power Chip ECU remapping, they have a stage 2 now for X6 it will put my X6 a wopping 288KW (according to the manufacture) on the wheel. Will Dyno it to find it out. on the wheel. Have already book in next wednesday for that power chip stage 2. Here are some photo of the finish products. Will take better photo after side skirt and side step fitted on. Thank you for viewing. Modification done so far 1. 21" BMW Double Spoke 215 (Black) 10J Front, 11.5J Rear. Done WK38/09 2. Brembo GT Brake kit (Red). Done WK47/09 3. kidney Grill (Black). Done WK47/09 Remove! 4. Hartge Quart pipe. Done WK51/09 5. Hartge lowering Spring (30mm). Done WK51/09 6. Vertice Body Kit (Fully carbon Fiber) Pending ! 7. ECU Remaping Stage 1 (PowerChip). Done WK52/09 8. Sprint Booster. Done WK51/09 Remove ! 9. Hamman 100% Carbon Fiber Roof Spoiler. Done WK10/10 10. Vertice 100% Carbon Fiber Trunk Spoiler. Done WK10/10 11. BMW Illuminated Door Sill. Done WK13/10 12. Robson Design Carbon Fiber Lamination Kidney Grill. Done WK17/10 13. H&R Wheel Spacer 12mm Front, 15mm Rear. Arrive!!! 14. VI Monitor. Done WK18/10 15. GoPRO Cam. Done WK47/09 16. Robson Design Carbon Fiber Lamination Fog Light. Done WK36/10 17. Robson Design Carbon Fiber Lamination Rear Diffuser. Done WK36/10 18. Robson Design Carbon Fiber Lamination Front Lip. Done WK36/10 19. Robson Design Carbon Fiber Lamination Side Skirt. Coming!!! 20. Robson Design Carbon Fiber Lamination Side Step. Coming!!! 21. ECU Remapping Stage 2 (PowerChip). Coming!!!
09-15-2010, 10:51 AM | #3 |
2nd to None!
42
Rep 296
Good Day!
1. AUD $8,000 with tire 2. AUD $10,000 3. AUD $4,500 4. AUD $1,100 (custom made fin fitted into OEM diffuser, it is carbon Fiber laminated)
09-15-2010, 12:15 PM | #4 |
Rep 117
Mods compliment your ride really well. But you are correct about the rear diffuser. Its a bit on the thick and square-ish side. And you might want to shorten the length....it looks too long. Short and subtle would look really nice.
09-17-2010, 02:53 PM | #6 |
Rep 106
first look i thought it was ACS body kit that was same on mine but it wasn't. Very nice new stuffs that I would like to get for my car too like the front grills.
Check out some of my mods all these i do it by myself. |
09-18-2010, 06:10 AM | #9 |
Rep 123
09-18-2010, 09:03 AM | #10 |
2nd to None!
42
Rep 296
It is in Australian Dollars AUD$
09-18-2010, 10:45 AM | #11 | |
2nd to None!
42
Rep 296
The side step that I am doing now is with Carbon Fiber and the rubber stud will still be showing along the side step. More CF for the Front and Rear lower bumper etc. As for the rear diffuser fin I think I will change it again to this Russia Tuner. One question I seen your Hamman wheel spacer, did you put it in your X6? If so can you post some picture of your car with the wheel spacer? Thanks.
09-18-2010, 05:17 PM | #13 |
Rep 106
Hi Audioquest,
Yes this Hamann spacer I made exactly like Hamann myself on my CNC machine as it was so difficult to get one. You know how long it takes to order it. So i just go ahead and put on my CNC machine to make 1 set just for myself. Here is the original spacer. I made it a bit thicker for the back, I think total thickness is 20mm. Front is 15mm. I ordered special bolts from Germany for it. It also depends on your tire offset and how wide you want your wheel shows out. Mine is just right at the lip, not showing out much but it looks pretty Ok, honestly I would like to have it out another 10mm but may need longer bolts. |
09-22-2010, 09:45 AM | #14 |
2nd to None!
42
Rep 296
Side Skirt and Side Step Carbon Fiber Lamination Progress. Would like to share with you guys, Just receive a few photo of my parts in the progress of Carbon Fiber lamination progress.
09-28-2010, 07:01 AM | #16 |
2nd to None!
42
Rep 296
Just got an update picture of my side skirt and side step Carbon Fiber Lamination. They are ready to be sent back to me by Robson Design from Singapore.
10-09-2010, 08:52 AM | #18 |
2nd to None!
42
Rep 296
CF Side Step and Side Skirt. Finally got it back from Singapore by Robson Design, the workmanship of the Carbon Fiber lamination is very good and it is a perfect fit for the side step and the side skirt. I am pretty impress by their workmanship. Have a look, what do you guys think?
10-15-2010, 01:44 AM | #21 | |
2nd to None!
42
Rep 296
Here is the link: http://www.bmw.com/com/en/newvehicle.../interior.html
10-30-2010, 12:37 PM | #22 |
Rep 129
Pretty sure hes using 3M carbon fiber wrap. You know, its like laminate
