07-26-2021, 05:13 PM | #1 |
Rep 20
Suspension crashes over bumps
The title says it all -- this is the harshest riding vehicle I've ever been in, and I want to make sure there isn't anything wrong with the suspension. The previous owner replaced the rear airbags, and they're essentially new. The local BMW dealer checked the undercarriage/suspension over the last time I had the vehicle there, and declared everything to be in good shape. And I'm not riding on run-flats, and the tires are inflated to spec. So I'm at a loss as to what's going on.
The vehicle has 141k miles, and hitting bumps is so jarring and so loud that it sounds like someone dropped a box of legos on a tile floor when I drive it. The lower part of the rear tailgate is constantly making "crashing" sounds when the car drives over bumps. It's just crazy. This has been a great vehicle otherwise, but it feels like there are blocks in each suspension spring that keep any sort of travel from happening. I might as well be riding on bricks on each corner. If you have ideas, I'm all ears. As it stands, I can only ride comfortably on glass-smooth roads unless I want to lose a kidney. Thanks for your help! |
07-26-2021, 09:59 PM | #2 |
Rep 551
The lower hatch on the tailgate can be adjusted, as well as the top half. Bunch of videos on YouTube showing how.
If the suspension really is crashing on bumps, I would start by looking at the shocks since that is what is meant to dampen vertical travel |
07-27-2021, 04:27 AM | #3 |
Rep 60
Can you distinguish whether it is front or rear? Also, did it start happening after the visit to the dealer?
If it is the rear then something has happened to the pressurising system... |
07-27-2021, 09:37 AM | #4 | |
Rep 20
It didn't start happening after the visit to the dealer, and I don't believe they did anything to make it worse -- it was there for a battery and a oil gasket, and they inspected the suspension, etc. and found everything to be in good shape. The previous owner replaced the airbags. The vehicle sits level, there are no codes, etc. so I'm not sure where to go next with troubleshooting. Patches in pavement feel like potholes -- there is zero give in this suspension. |
07-27-2021, 06:39 PM | #6 |
Rep 40
I had a similar problem with my 2010 E70. I ended up doing a suspension refresh about a month ago. I asked for a "beefier" setup.
For the rear suspension, my mechanic replaced: - rear shocks - bellows - bump stops - mounts After these were done, the ride wasn't as harsh anymore.. it changed to be a lot more "bouncy" but no smashing or bottoming out, if that makes any sense? (My car is aggressively lowered). Here's a before and after comparison. Sorry for the bad quality... these are screenshots from video inspections. Last edited by predicate_logic; 07-27-2021 at 07:04 PM.. |
07-27-2021, 09:03 PM | #7 |
Rep 4,216
If prev owner lowered the suspension at some point during their ownership, chances are the rear links may not be stock. Would be worthwhile to check, and replacement /installation is easy and inexpensive.
2020 F87 M2 Competition /l\ LBB /i\ Executive Package 2013 E70 X5M /l\ Space Grey /i\ Full Silverstone Leather /l\ LED Headlights /i\ Comfort Access /l\ HUD /i\ Ventilated Seats /l\ 22" BBS SV BMW CCA Member |
2011with140k1.00 |
07-28-2021, 12:51 PM | #8 |
Rep 20
07-28-2021, 04:31 PM | #9 | |
Rep 20
Thanks for the great info! |
07-29-2021, 12:48 AM | #11 | |
Rep 40
Anyways, here's what my invoice says for the rear suspension work: Labor: - $449.97 Parts: - Rear shock absorber left - $1,011.22 - Rear shock absorber right - $1,011.22 - Shock mounts x2 - $127.87 - Shock mount gasket x2 - $4.81 - Shock bump stop x2 - $32.83 - Special order shipping - $81.18 Grand total: - $2,884.61 Good luck! I hope this helps you |
2011with140k1.00 |
07-29-2021, 01:57 PM | #12 | |
Rep 60
These prices are for an X5M (with EDC)? It looks like OP owns a 35i? If so, the parts prices should be cheaper. On ECStuning, a rear Sachs shock for self-leveling suspension is $171 each. Going non-BMW, (but OE; I believe Sachs is OE supplier to BMW, generally) would be the cheapest option. Other options include Bilstein (B4s). |
2011with140k1.00 |
07-29-2021, 09:55 PM | #13 | |
Rep 40
08-07-2021, 08:45 PM | #14 |
Rep 20
One more stupid question: Is there any reason I need a BMW mechanic for shock replacement? This seems like it should be standard and similar to any other vehicle, but I thought it would be worth asking before scheduling service.
The rear airbags have already been replaced, so I'm just looking at replacing the actual shocks. Thanks! |
08-09-2021, 04:38 PM | #15 |
ESS Tuned 700+ HP
Rep 12
My front bump stops were GONE
One day out of the blue it started. Hard bump resulted in what sounded like something broke in my suspension but aside from the big bumps everything was fine. First couple times it happened I had to get out expecting one of my wheels to be bent but were all fine......... My suggestion is to check that the front bump stops are there intact. Don't just look at the boot that covers them, that is why it easy to miss if the dealer was just doing a 'visual'. About $50 for the parts but it's the labor that is Brutal......
2011with140k1.00 |
08-10-2021, 09:27 AM | #16 |
Rep 876
Shot in the dark here, but confirm shock tower nuts torqued front and rear. Easy to access. For that matter check the torque on the rest. I posted a checklist in my build thread with suspension torques (associated w strut removal/install), last page. GL.
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
2011with140k1.00 |
