      11-11-2023, 09:22 PM   #1
awdowns
Drives: 2011 X5 50i
1999 BMW 323i  [0.00]
2011 BMW X5 50i  [0.00]
Water pump pulley grooved vs smooth
New N63 owner here and I am changing the water pump on my 2011 X5 50i.
The pump I removed from the vehicle has a grooved pulley. The replacement I ordered from FCP Euro has a smooth pulley. Every replacement pump picture I have seen online has a smooth pulley including the drawing on RealOEM.
The way the belt was routed has the grooved side riding on the smooth water pump pulley. I've never seen a routing that has the grooved side of a belt riding on a smooth pulley before.
Can someone confirm if this is correct / normal?
      11-12-2023, 01:06 PM   #2
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
Looks like a part number change from a 11517548264 to a 263 (superseded part is the 264 for some reason). If you google image search the 264 you can see grooves. The newer 263 doesn't have them.
      11-12-2023, 03:18 PM   #3
tomjonesBT33
tomjonesBT33's Avatar
Drives: 2006 Z4 M Roadster
Correct, the new pumps do not have grooved pulleys. I replaced mine last year and the original and replacement both have smooth pulleys. Both are/were original BMW parts. I’ve never seen this before either, but that’s how they are.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic
2012 X5 M - Monte Carlo Blue Metallic
2017 X1 xDrive28i - Alpine White
      11-13-2023, 08:17 AM   #4
awdowns
Drives: 2011 X5 50i
Thank you guys for confirming.
This really had me scratching my head. I had never seen this before.
11517548264 does return images of a grooved pulley. Interesting they chose to do that. The grooved pulley pump I pulled off had "Gates 43015" stamped on the pulley and even a google search for that one comes back with images of a smooth pulley now.
