      06-22-2021, 09:41 AM   #1
AnotherArchitect
Saudi Arabia
24
Drives: X5m E70|PP Performance Tune|DP
Cooling Upgrades for x5m e70
Living in the desert is mostly riddled with cons, but the one con, in particular, that really sets things apart for turbocharged cars, is the heat.
As we all know, the S63 doesn't respond well to heat and lots of parts fail and need replacement in the process.
I'm looking for advice on the best way to mitigate that issue; whether it's aftermarket parts or home DIY stuff and I believe the forum is a good way to keep those things documented.
I've personally done the following:
1. switch the original thermostat to a 90C thermostat
https://www.ecstuning.com/b-hamburg-...37586885-90c~/
2. turbo blanket
https://www.ptpturboblankets.com/col...5-m-x6-m-m5-m6
3. Removed the back engine cover and weather stripping
Share your thoughts and advice on what else can be done to help engine live longer and survive in horrible temps.
(I sincerely apologize if this topic has been previously discussed; I'm just looking to compile it all in one thread)
      06-22-2021, 01:24 PM   #2
mitch808
Drives: 2012 X5 35i
Waterwetter has a new pre-mixed coolant. There are documented 10-20deg drops in temp, with this fluid alone.
If it meets the spec, I'd recommend it. Other wise, you can do more of a 70/30mix of water to coolant and waterwetter additive.
      06-22-2021, 02:58 PM   #3
zoom750
Drives: 2013 X5M
There's also the lower temp oil cooler valve.
https://n63intake.com/collections/be...l-cooler-valve
You could also wrap/ceramic coat your cats.
      06-22-2021, 04:49 PM   #4
Sophisticated Redneck
Drives: 2012 BMW X5 50i
2. turbo blanket
Being a fellow desert dweller, I know your pain (it was 118 here in Arizona just a few days ago). Both the N63 and S63 being nearly identical, have this same issue. Besides what you have already done, below is the heat shielding I added and it made a huge difference. All will apply to the S63, the only difference you will see is in the exhaust manifolds are different on the S63 vs N63 but should still be able to be wrapped. Links to everything I used below. I can't recommend the Titanium exhaust wrap enough, even after 40K miles it still looks and performs like new. Make sure to get the real stuff and not cheap knock offs.
1 - If you haven't already, trim rain gutters down 1/2" inch where is meets the hood, this allows for addition airflow and still allows proper water defection.
2 - Cut and Rivet heat shielding to to fit under factory turbo oil heat sheild.
3- Wrap Manifolds in 1" wrap.
4- Wrap Downpipes/cats in 2" wrap
5- Cut heat shielding to size to fit underneath stock oil catch pan/heat shield under turbos.
6 - Cut heat shielding to size to fit on top of turbo/cat main heat shield.
7 - This is also an excellent time to replace the head to head coolant line and wrap it in heat shielding (which always goes bad) and turbo/pressure converter vacuum lines and update the plastic T fittings on the turbo coolant lines to stainless steel.
Here is what you will need
2 x DEI 1" wrap (for manifolds): https://www.amazon.com/gp/product/B002R4XL2Q
2 x DEI 2" wrap (for downpipes/cats): https://www.amazon.com/gp/product/B002R4U72I
1 X Stainless steel ties: https://www.amazon.com/SunplusTrade-.../dp/B072WC1MXT
1 x Locking tie tool: https://www.amazon.com/Design-Engine.../dp/*****U1UOI
1 x Heat Shielding for engine valley and turbo shield:https://www.amazon.com/gp/product/B00YJERW40
m5james431.00
TTV8M123.50
      06-22-2021, 07:34 PM   #5
Autobacs
Autobacs's Avatar
Drives: 2019 BMW X6M
Go Cat-less Downpipes if you can. The catalytic converter generates a large amount of the heat in the engine bay and going cat-less will significantly reduce under hood temperatures.
2019 BMW X6M
2013 Lexus RX450H
2010 Nissan GTR AMS Omega 14
m5james431.00
      06-24-2021, 01:47 AM   #6
AnotherArchitect
Saudi Arabia
24
I will definitely check this out! I hadn't heard of it until now. 10-20 is a bit deal!
      06-24-2021, 01:49 AM   #7
AnotherArchitect
Saudi Arabia
24
Oil cooler valve seems legit! I'll order one ASAP.
I'm going with carless downpipes soon... So I guess 1" wrap will be a better option for that.
      06-24-2021, 01:50 AM   #8
AnotherArchitect
Saudi Arabia
24
You are a blessing to this community! I've been through most of your posts and I can't thank you enough!
I'll definitely go through this list and follow all of this!
      06-24-2021, 01:51 AM   #9
AnotherArchitect
Saudi Arabia
24
I will! Placing the order on VRSF next month.
      06-24-2021, 09:55 AM   #10
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
I wouldn’t recommend removing the “back engine cover and weather stripping” if you mean the plastic engine partition. They serve a purpose to keep the rain out of the engine bay. The water does over time damage injectors and electrical components as well as corrode the engine bolts. Unless you plan to never drive it in the rain. I cant say if it lowers under hood temps a meaningful amount as I don’t recall anyone doing before and after measurements. Just some anecdotal reports. Unlike some of the other mods like hood louvres.
The lower temp oil cooler is fine in the summer. But could keep oil temps too low in the winter to burn off water/fuel. There are downsides to this mod.
No downsides on the low temp thermostat as far as I can tell.
No downsides on a turbo blanket
Catless dp, makes it hard to pass inspection if you have a state that requires it.
Personally I’ve done, low temp coolant thermostat, turbo blanket, and heat shielding on oil and coolant lines. I run mine in pretty extreme conditions most of the time and these mods seem to be fine. I tow in 100+ heat at full throttle for long stretches.
      06-24-2021, 10:49 AM   #11
Thanks! Happy to help =)
      06-24-2021, 11:52 AM   #12
I spent many hours testing what made a difference, the back partition is appears to be mainly for sound and engine bay odor suppression, the plastic rain gutters even with 1/2" trimmed off the top still keeps nearly all of the rain off the engine. What little does make it is quickly evaporated off.
I also used wireless thermal probes to conduct highway, city, and parked temps. I recorded a 20 degree drop on average in city driving, highway would run cooler partition-less much sooner, but the biggest difference is actually in parked temps. It shaves 30-40 degrees depending on the location in the engine compartment. When I conducted the tests it was 116 out. With the partitions in place and the engine bay reached 220-240 degrees after 15min parked and stayed in that range for hours. With the back partition removed and the gutters trimmed, peak temps were 167-190 degrees in the engine compartment. It also cooled down to ambient temps on average 3 hours earlier then with the partitions. This is when most of the high temp oxidative damage to all the plastic and rubber bits under the hood occurs.
It does have its downsides, there will be more dust and dirt allowed into the engine compartment, you will hear your injectors clicking away (as well as sweet turbo noises!) and I do not know how snow would effect it as being in Phoenix, I have only seen pictures of that white stuff. But for us desert dwellers where heat is the number one enemy of our cars and trucks, I highly recommend it.
      06-29-2021, 06:47 AM   #13
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Just do the lower temps tstat and clean out your coolers. I am here in a high heat and high humidity and very harsh environment (125f air temps, Ground temps are higher) and my X5M never even reaches half for the oil temps and runs cooler as far as water temps are concerned. Also I used one bottle of water wetter in the turbo coolant and 2 in the radiator as well.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
IG: @060Motorsports
      06-29-2021, 07:15 AM   #14
Thecastle
Drives: F10 550i
2020 BMW X3  [0.00]
Good Data. Though with all of the problems I read from folks who have leaky engine partitions. Plus living in a sub tropical climate where we have had weeks of rain, I'm sticking with my low temp thermostat and turbo blanket ;-)
I will comment that the low temp thermostat and turbo blanket have noticeably reduced underhood temps. I remember after towing opening the hood I'd be welcomed with a blast of heat. Now I don't feel anything but I know its warm in there. Anecdotal I know.
My X5M is used mostly as a tow vehicle and burns 0 oil and was generally healthy before the mods. It has 66K miles now. I've been running a low temp t-stat on this car for 1.5 years, and a turbo blanket for 1+ years, and heat sheilding over the turbo lines. Though all of my turbo coolant lines, oil lines, and oil return block seals have been replaced before I added the turbo blanket. Also had to replace the electric turbo cooling pump.
      07-03-2021, 02:21 PM   #15
Autobacs
Autobacs's Avatar
I do NOT recommend VRSF Down pipes for the S63. I have a separate thread on my experience with them. Pain in the Ass and did not fit for me, with install attempt done by a BMW/MB specialty tuning shop.
2019 BMW X6M
2013 Lexus RX450H
      07-03-2021, 06:56 PM   #16
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
I've read about many others having issues with VRSF install as well. I've been running Active Autowerke for the past 2 years and can say build quality was excellent and install was straightforward.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
      07-15-2021, 07:20 AM   #17
AnotherArchitect
Saudi Arabia
24
THAT bad? :/
      07-15-2021, 07:25 AM   #18
AnotherArchitect
Saudi Arabia
24
I don't have any "heat" issues, I just hate that it normally runs at such high temps. I've used the BMW coolant for both; I'm assuming from your experience it's better to use red line's WW?
Sometimes I get the "itch" to step on the gas a little; I worry about the heat ruining the internals slowly but surely. So, whatever helps it last longer, I'd do it.
Good to hear from you
      07-15-2021, 08:59 AM   #19
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Turbo blankets is prob a bad idea on this setup you're going to keep extra heat near the back cylinders.
      07-15-2021, 12:53 PM   #20
Autobacs
Autobacs's Avatar
THAT bad? :/
So bad it made me write an article about it to spare others the frustration. I mean you already have other people saying the same thing so not sure what other proof you need. I would hate for you to try it and experience the same thing
2019 BMW X6M
2013 Lexus RX450H
      07-16-2021, 05:40 PM   #21
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Great suggestions in here, I've done many and will be doing more from this post. What I didn't see is running Evans Waterless coolant, which I've been running for about 4yrs now. Slightly expensive but ZERO pressure on BMW's notorious use of shitty, brittle plastics. I've driven from Seattle to Hollywood to Vegas (Bimmerfest trips) and countless places in between, currently have 144k and around 700hp, all without cooling issues.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      07-16-2021, 07:11 PM   #22
m5james
m5james's Avatar
Are the lengths/quantities correct via the links?
- 2 rolls of 1"x50' header wrap...seems like a lot but then again I'll be wrapping S63TU manifolds
- 2 rolls of 2"x50' DP wrap...I've already wrapped mine but wasn't sure if it was used elsewhere while you're at it
- 100 SS exhaust cable ties...I used safety wire from work but this would probably work better
- your locking tool link is broken but I found "Design Engineering 010220 Locking Tie Tool"
- 1 sheet measuring 42" x 24" or 7 sq ft...you just lay this in the valley pan before putting the turbos back in?
TTV8M123.50
Tags
x5m
