      04-27-2021, 11:35 PM   #1
liam821
Drives: e46m3 e93m3
delete rear seat not lock warning
I've done a 3rd row delete and all went fine except for the rear seat not locked error. I'm sure there is a parameter in ncs expert to disable it but I can't seem to find it.
I haven't removed $4UB from my VO since I didn't think that would do the trick, I figured it's some parameter in some module I just don't know which one.
Can anybody point me in the right direction to disable this check?
Pheonix Yellow e46m3
Melbourne Red e93m3
      04-28-2021, 08:49 AM   #2
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Any chance you'll be doing a write-up on this? I would like to remove my 3rd row as well.
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP
Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190
      03-11-2022, 08:31 PM   #3
e46IX
Drives: Z4MC, E92 M3, F80 M3
Did you ever find a resolution to this? I'm experiencing the same issue (3rd row delete) and can't figure out how to clear the annoying dash warning.
      03-12-2022, 12:25 AM   #4
liam821
Drives: e46m3 e93m3
Sorry, I just saw this. I don't really have a write-up on this. There is a lot of parts you need though.
Just from memory:
obviously the rear seat and seat base
C & D pillars (they're different)
rear carpet
different trunk cover and all the misc parts under the rear cover. Plus you need all the trunk side covers
rear seat base and seat belts
Basically, everything from the rear seat back is different. You're better off finding a crashed x5 and swap everything as I did.
The lock warning is just a simple switch, if you bridge the two wires together it will trick the system into thinking the seat is locked. So I literally just connected the two wires together that go to the seat lock switch which fooled the car into thinking the seat was down. Haven't had a problem since!
Melbourne Red e93m3
      11-05-2023, 07:54 PM   #5
bfunk04
Drives: 335d
Just from memory:
rear carpet
Anyway you can expand on this? Which two wires did you bridge together?
