      02-29-2020, 12:30 AM   #1
lutecki
Drives: X5 and 300C
K-CAN1 - wakeup front seats
Hi everyone!
I have crazy project. I try use front seats (full comfort version) from X5 in my 300C, but when I plug in the +12V supply , nothing happens. I have read many materials and came to the conclusion that I must communicate with them via K-CAN1. On board (module have number 9221863) I see TJA1055 low-speed CAN transceiver, so I think the speed is 100 kbps (K-CAN1).
I don't have full car like X5/X6, only seats so I can't sniffing K-CAN frames, I must search "frames" on Google and try send to seat module.
I think I must send "wakeup frame" in any 500 ms but data I found on the internet don't do anything. The module doesn't respond to any frames, it doesn't even send an ACK signal, nothing... I try other bus-speed like 500 kbps. I have two modules and both behave the same. After 10 seconds from connecting the power supply, the module goes into sleep mode, begins to draw less power (almost 0.01A).
I try send to this module few frames from many websites:
0x130 - 45 40 21 8F FE
0x202 - FD, FF
0x202 - FD, 00
0x273 - 1D E1 FF F0 FF 7F DE 04
0x202 - FD
0x563 - 63
I try use codes from http://www.loopybunny.co.uk/CarPC/k_can.html read diagrams/plugs from https://www.newtis.info/tisv2/a/en/e...ver/1VnbfaSSA2 and still nothing.
Does anyone know how to wake up these seats?
      06-24-2022, 10:07 AM   #2
Seathack
Drives: BMW 325xit, 69 VW dune buggy
Hi Lutechi,
Did you ever get the seats to work? I have the same problem! There is a company in your part of the world called “seatscontrol” that makes a device specificity for this, but they don’t respond. There is also a good thread on bimmerfest about k can spoofers
Cheers!
      11-09-2023, 10:27 AM   #3
skuirbreaker
Drives: honda ridgeline
I have the same seat & I am also trying to power the seat
I have the same seat & I am also trying to power the seat outside of the car.
Have you made any progress?
https://photos.app.goo.gl/YBrgU3dXJ9KwUEMW6
      11-09-2023, 11:37 AM   #4
Daytonawim
Drives: X5 E70 LCI 3.5i 2012
I should work, the Seats are the same as the where in my E90 2012.
I replaced the manual Seats with the electric one with memory.
Because of the Leather color, I replaced the leather and had to power the Seat to get acces. I only used a 12 volt power source.
I will check If I have the pictures saved or they are at one of the E90 forums.
