      04-27-2019, 11:08 AM   #1
OneSickM
OneSickM's Avatar
122
Drives: M3
Are there transfer case problems with E70 X5 platform?
I have searched thoroughly but I couldn't find an answer.
Are there reported issues with transfer case on the E70 X5? and how do you tell if my car has this problem or not?
All results on my search are just pointing to F30 platform (3 series).
      04-29-2019, 10:20 AM   #2
pearlpower
Drives: 2013 328i
Not as much that plagued the E53 models. The E70 appears to be far better.
      04-29-2019, 11:07 AM   #3
OneSickM
OneSickM's Avatar
122
Drives: M3
so this means there were still reported issues? Is this easy to fix or expensive?
      04-29-2019, 11:49 AM   #4
HedMan
Drives: 2011 X5 35i
I have a 2011 E70 (xdrive35i) that came to me with transfer case problems...at slow speeds (parking lots) it would keep the front wheels at the same speed, so would shudder when turning (it is supposed to disengage the front wheels completely at slow speeds).
Changing the transfer case fluid and and resetting the TC adaptations solved it for me.
      04-29-2019, 12:53 PM   #5
heatmizr
Drives: E70 X5 50i M-Sport
My 2012 exhibited some "crabbing" of tires when turned sharp in a parking deck (guessing same as the poster above calls shudder - basically not smooth rotation). I mentioned it to the dealer at a service visit and they confirmed and replaced the entire Transfer Case under warranty. This was at about ~50k miles.
The crazy thing is, 7-8k miles later, I swear that I can feel a little bit of the same thing with the new transfer case already.... Maybe its nothing...? lol
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      04-29-2019, 01:21 PM   #6
OneSickM
OneSickM's Avatar
122
Drives: M3
Ok thanks for the input. How did you determine that the front wheels are at same speed when the car is rolling on the ground?
      04-29-2019, 01:38 PM   #7
heatmizr
Assuming he was guessing since the transfer case was not working properly and so must have not been adjusting the wheels for turning radius. Which is the phenomena/feeling I called "crabbing". I have no recollection where I got that term from...
heatmizr [Todd]
e90 328i - sold
OneSickM122.00
      04-29-2019, 04:11 PM   #8
HedMan
Drives: 2011 X5 35i
There are a lot of other threads on this problem, and several mentioned that it felt like driving with a locked differential (like in a Jeep with a diff lock).
It's basically the same thing... if the transfer case is locked, the wheels turn at the same speed, so when the car turns and one of the wheels needs to turn faster than the other, it kind of shudders (or crabs...I like that) as one of the tires keeps trying to catch up with the other one.
Even if that's not exactly what is happening, if your problem is shuddering/crabbing at slow speeds when you turn, chances are it's the transfer case.
      01-03-2020, 11:32 PM   #9
X5_montrealer
Drives: 2011 x5 M-package
Sorry to hear about your issues, I have a brand new BMW transfer case for sale, if It could help.
It was purchased with oversight and doesn't fit in my 6 cylinder truck. I also put in a $200 bushing. Part # 27107643752 Please verify fitment! I believe it's from a 2011-13 X5, 8 cylinder, but it will fit other models. The warranty on this unit is two years from its purchase date of May 10th, 2018 No core charge, no tax! Thanks
Thanks,
Bruce
514-966-6777
b_bradshaw@mac.com
      01-04-2020, 10:04 AM   #10
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
I have had a 2008 E70 4.8i sold at 98K miles no problems with xfer case. I now have a 2011 E70 X5M with 62k miles no problems. I really don't read about a lot of problems with the xfer case on the E70s. Except modded X5M owners who floor it while turning and blow one (1 case).
      01-04-2020, 03:16 PM   #11
peter2772000
Drives: 2012 X6 35i Sport
I've got the same issue with our 2012 X6 35i Xdrive. Going into the dealer Monday for a t-case oil change, sure hope this fixes the problem. It's getting progressively worse with every 100 miles driven
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      01-06-2020, 08:34 AM   #12
Spyro235
Drives: '10 X5D, '04 330i ZHP
How did noone comment- The actuator is a pretrty common problem. What happens it hthat teh metal actuator worm gear strips out the nylon/ plastic actuator gear which moves the clutch. The gear is a $20 part on amazon prime, and you the gear, new fluid, and ista adaptations all at the same time. Makes it smooth as silk.
Daily/ Tow: 2010 X5 35D - 326k, Deleted w/DUDMD Stage 2, Sutphin Trans tune, Comfort seat retrofit
Fun car: 2004 ZHP 6mt - 256k miles, z4m FCAB, stock. Drift car: 2001 330i for sale
      01-06-2020, 01:59 PM   #13
peter2772000
Do the dance, do the dance....
Oil change and recalibration of the t-case did the trick. And not $800 as was mentioned somewhere, but $233 tax in. I was so relieved, I filled up the loaner (new X3) although I only put around 12 miles on her. Also bought a $100 Visa gift card for my advisor who's always doing his best for me.
So relieved. Was quoted $4100 for a new t-case.
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      01-07-2020, 12:59 AM   #14
och
Drives: .
2012 X5 xDrive50i  [0.00]
2018 BMW M2  [0.00]
2017 X6M  [0.00]
2013 Suzuki Bouleva ...  [0.00]
I replaced mine under warranty with about 20k on the clock. I believe they put in a revised unit.
      01-07-2020, 10:01 AM   #15
Huz-Z
Huz-Z's Avatar
Drives: Z4 3.0si, 328 XDrive, X5 35i
Transfer case issues are common on 2012 model year X5s. I had mine replaced under the extended warranty in July 2019.
For my vehicle the problem appeared as a slight shudder / chatter from dead stop , and only after I installed a new set of staggered summer rims and tires. The problem went away when I put the original square set up back on the car for winter. Just the same, I had the transfer case replaced and it’s been fine since.
      01-07-2020, 03:10 PM   #16
peter2772000
Mine is an X6 2012 with 50k miles. Way too young for needing a new t-case. Did anyone (except Hedman) who had this shuddering first have the oil replaced to see if that cured it?
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      01-07-2020, 04:51 PM   #17
Huz-Z
Huz-Z's Avatar
My 2012 X5 had about 45,000 miles on it when I first became aware of the transfer case problem in mid 2018. I put up with it until July 2019 and had it replaced at that time.
This is a known issue on 2012 vehicles and BMW really should be looking after the full cost of this even if the car is out of warranty. Thankfully I have a good third party warranty that covered this for me.
      01-08-2020, 09:42 AM   #18
peter2772000
Did you try having the oil changed first?
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      01-08-2020, 09:46 AM   #19
Spyro235
I replaced my stripped gear, and changed the oil. Buttery after that, though I'm starting to get a little clunk when coming to a stop. I'm going to rerun the adaptations sometime soon again and see if that helps. For the record, it's been about 5 weeks since I fixed it, and around 4.5k miles.
      01-08-2020, 12:22 PM   #20
Huz-Z
Huz-Z's Avatar
Nope - the dealer advised that the transfer case was shot, but covered by my extended warranty, so I let them go ahead with replacing the old transfer case with a new one.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package.
      01-08-2020, 01:12 PM   #21
och
Drives: .
2018 BMW M2  [0.00]
2017 X6M  [0.00]
https://www.xbimmers.com/forums/show...light=transfer
      01-23-2020, 11:43 PM   #22
svt1998gt
Drives: 2008 e90 335i, 2012 X5 M spor
i had the issue for a while, finally pulled fuse f92 and the car drives nice. will go for the xdelete instead of fixing it.
