      03-18-2024, 05:53 PM   #1
Jakg
Drives: 335d
4x4 error / pops back in park / check my fault codes
I've got a 2010 X6 40d, which will pop back to park when you select drive / reverse.
It will get a gear up in the air (car is on stands), but when on the ground it'll pop back into park. And I get the 4x4 etc warning on the dash. I've got the following faults:
View post on imgur.com
I've tried the following:
  • New AGM battery (registered) - old one was 7 years old
  • Replaced the alternator regulator - old one was overcharging
  • Changed transfer case oil (& calibrated) - clearing existing "oil wear" fault
  • Swapped the gear selector lever - clearing existing fault
I'm leaning towards an electrical issue rather than mechanical.
Any thoughts?
